Chris NottEM Tuning
Results 1 to 16 of 16
Like Tree1Likes
  • 1 Post By pj123
Thread: strange noise...
    Jan 2014
    Worcester
    185
    strange noise...
    When ever I loose traction when maneuvering on grass or something slippery I hear a noise like a muffled wet fart. Anyone else had this? Should I be worried lol
    If in doubt, flat out!
    Dec 2013
    Alnwick, Northumberland
    37
    maybe abs pump, if so that is normal (when abs kicks in or traction control)
    Audi S3 Imola Yellow APY
    N249 Delete, 80MM TIP. About to carry out major engine surgery :S
    Jan 2014
    Worcester
    185
    No traction control, just realised the car has drilled and grooved disk's, would that make a noise like a cable tie spinning against something? Its not there while driving normally, just when traction is lost at low speeds
    JUS3IN's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    695
    could be an inner cv on its way out, i had a mk3 vr6 on coilovers years back and when dropped low it would eat the inner cvs... hated changing them aswell. could the noise be from the diff if the wheels spinning it would be working hard, dont/didnt the fwd golf turbos have problems ripping all those rivets out around the diff housing.. do the a3's suffer that?
    sorry op, not trying ta put the fear of god in ya, probably just something loose and rattling...
    1999 apy s3, n249 delete, sai and n112 delete. bbs lm reps, s2000 filter, relentless v3 manifold, relentless downpipe and sports cat, scorpion cat back system, badger 5 v3 tip, bam rocker cover, push in coilpacks, toyosports fmic, amd remapped to 280.3 bhp and 263.9 lb/ft.
    Jan 2014
    Worcester
    185
    Its not been lowered and makes the noise just rolling off the clutch if on slippery mud, there are 7 cars on my front garden in almost daily use so the grass gets chewed up a bit. Is the abs on a pre facelift a3 mechanical or electrical?
    Spatula's Avatar
    !.8T AGU
    Jan 2013
    North West
    191
    Mine does this exact same thing, I think it's traction control kicking in, but sounds like the clutch is trying to bite a cheese grater or something.
    Sub'd for answers!
    Jan 2014
    Worcester
    185
    That's the sound, no traction control on mine as it too old lol
    Spatula's Avatar
    !.8T AGU
    Jan 2013
    North West
    191
    To be fair, mine doesn't have traction control either. Not sure what it is? Does it feel like you could put your foot down and that noise would just continue like it's restricting the engine being connected with wheels?
    JUS3IN's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    695
    clutch on the way out or diff... could still be a failing cv... best thing you could do is take it to a garage and they probably wont charge you to tell ya what it is. its hard to describe to people on noises through text.
    Jan 2013
    Mine does this to pretty sure it's the haldex clutch
    Jan 2014
    Worcester
    185
    Mines not 4wd though
    Oct 2010
    Hampshire
    294
    Its normal, you may not have traction control but you do have EPC which will prevent wheels spinning below 30mph. Fitted to the early A3 and S3 models before traction control came in around 2000/ 2001. Noise you hear is the abs pump and it uses the brakes to prevent slip aswell as a few other controls that kill power to the engine. I have a 99 s3 and it does it when on wet grass or loose gravel, i never get a light to say it is operating, you can only hear it.
    lol4fun likes this.
    Jan 2014
    Worcester
    185
    That's cute, how do I turn it off?
    Mar 2014
    29
    pj123 I have this same problem today abs light as come on and the left front wheel is locking up?/auto braking it has also done this when the abs light as been off mine is a a3 1.8t 99 so before traction control no esp button,what could be causing this? cheers
    Oct 2010
    Hampshire
    294
    the only issue i have had on this system is the esp light on because of a faulty brake pedal switch. you need to get a scan to diagnose the cause.
    Mar 2014
    29
    it came up fault on front abs sensor so i have replaced the front abs sensors but they wudnt fit in the hole so I shaved some off them to fit now iv been told I should of cleaned the housing I cant see how that would make any diffrence tho
  1. Strange Noise when reversing
    By Nimo in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th December 2009, 18:40
  2. Strange noise?
    By imported_velcrobix in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th August 2004, 18:29
  3. Strange Noise - Sounds like BOV
    By godwine in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th May 2004, 22:52
  4. Strange noise..
    By s8n in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th August 2003, 00:44
  5. Strange noise - anybody got a clue !?
    By audi_girl in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st February 2003, 16:52
