Volks AutosEM Tuning
Results 1 to 30 of 30
Thread: S3 Front discs
    Nov 2004
    6
    S3 Front discs
    Had some EBC dotted and grooved front discs on the car and they warped badly after a very short period of time. What discs do people recommend for the S3. Has anyone experienced warping of the OEM discs ?
    Numptie of the highest order
    Jun 2004
    Crowthorne, England
    2,512
    Re: S3 Front discs
    I think unless your doing track days the standard breaks are fine, I fitted replacement discs and pads at the end of last year from www.eurocarparts.co.uk and they are great.
    www.vwspares.co.uk are also worth a look if your going DIY.
    Nov 2004
    6
    Re: S3 Front discs
    Thanks for that info, Are there any specific tools required or any special fitting instructions for changing the front discs on a 1999 S3. I am fairly compitent mechanically. How long should they take to change ?. I would have thought around 30 or 40 minutes per side.
    Oct 2003
    South Wales
    2,942
    Re: S3 Front discs
    I've never actually changed the discs and pads on my S3 but I would assume its very straight forward. Get yourself a piston winding tool from halfords and thats all you should need (apart from the usual tools)
    Oh and perhaps some copper grease. Discs are normally held on by a screw which is easy to remove.
    Hope this helps.
    Nov 2004
    6
    Re: S3 Front discs
    Yea thats what I thought it would be. easy enough. Thanks
    Jun 2004
    Crowthorne, England
    2,512
    Re: S3 Front discs
    should be very easy, the only problem I had was removing the little screw holding the disc on to the hub for fitting, so make shure you coat the bugger with WD40 and try and get the screw out in one piece!
    Nov 2004
    6
    Re: S3 Front discs
    I find an impact driver works very well for this and it just so happens I have one [img]/ubbthreads/images/graemlins/smile.gif[/img]
    S3_MCD's Avatar
    Dec 2003
    Bristol
    390
    Re: S3 Front discs
    45 mins for the first side ..... 30 mins for the 2nd.
    fairly straight forward.
    as for recommedations - black diamonds, drilled and grooved - great stopping power - no fade what so ever!
    Nov 2005
    Derby, England
    Re: S3 Front discs
    Fully agree with S3_MCD, Black Diamond discs/pads all round, they are [img]/ubbthreads/images/graemlins/swear.gif[/img] hot.
    But the little screw can be a b'stard to remove.
    Also, I use a standard G-clamp for pushing the caliper piston back in, about a fiver from Wickes...
    Jun 2004
    Crowthorne, England
    2,512
    Re: S3 Front discs
    [ QUOTE ]
    [/ QUOTE ]
    Doesn't work on the rear though and the right tool for the job is only about 10 from halfrauds - just a thought! [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,578
    Re: S3 Front discs
    I had bought some of the Brembo items from GSF......cost 110 for bothdiscs and pagid pads!
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,578
    Re: S3 Front discs
    Look OEM and an improvement on the originals for sure!
    imported_VaulterTim
    Re: S3 Front discs
    Lovely wheels dude [img]/ubbthreads/images/graemlins/ok.gif[/img] They look brand new... shame about the tyres [img]/ubbthreads/images/graemlins/tongue.gif[/img]
    Nov 2003
    S tAlbans
    70
    Re: S3 Front discs
    can you give us a picture of the whole car Mike as I've thought about these wheels... Thanks
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,578
    Re: S3 Front discs
    Dec 2004
    cornwall
    229
    Re: S3 Front discs
    ive got a brembo setup and the second pair of discs have warped, anyone got any suggestions of some good discs?
    Nov 2003
    S tAlbans
    70
    Re: S3 Front discs
    Thanx for the pictures. Nice wheels and like the red calipers
    recomdos's Avatar
    Feb 2004
    North East
    988
    Re: S3 Front discs
    I would like the Brembo discs like Mike's. I called GSF, and they don't stock them...grrr! So does anyone else know where to try? Failing to find anything, the choice looks like it will be between ATE from eurocarparts and zimmerman from GSF.
    I'd be interested to hear any other opinions.
    Cheers [img]/ubbthreads/images/graemlins/smile.gif[/img]
    imported_velcrobix
    Re: S3 Front discs
    I'm going to need new front discs soon and looking at black diamond drilled/grooved but a little concerned about reports of drilled discs 'cracking'. Has anyone experienced this with black diamond discs?
    S3_MCD's Avatar
    Dec 2003
    Bristol
    390
    Re: S3 Front discs
    [ QUOTE ]
    [/ QUOTE ]
    no problem with mine.... and that is with hard driving.
    I believe its "normal" for drilled disc to show small fracture lines spreading from the holes, but these are very small, not what i would call 'cracking'.
    that said mine are fine, and offer far better brake feel with no fade whatsoever!
    good choice
    imported_velcrobix
    Re: S3 Front discs
    Cool, may order some at the end of the month with the preditor pads.
    S3Steve's Avatar
    Sep 2005
    Peterborough
    1,588
    Re: S3 Front discs
    Black Diamond discs are good but I'd go for Ferodo DS2500 pads
    imported_velcrobix
    Re: S3 Front discs
    I was going to get the preditors because they are also 'dust reducing' pads. What are the Ferodo's like?
    Obviously i want pads that reduce fade but i dont really want pads that need to warm up alot before they work properly. Don't fancy being caught if i have to brake hard on motorway journeys with cold pads/discs.
    imported_rashpal1
    Re: S3 Front discs
    I recently replaced my pads and discs at the front. I went for the following:
    Tarox G88, 40 Groove discs
    Tarox Strada Pads
    BF Goodridge braided hoses all round
    ATE Super Blue Brake Fluild.
    This all cost about 320, fitted by myself..
    I chose to go for grooved ones as i heard too many stories of drilled ones cracking.
    Massive improvement over stock setup, no brake fade at all.. Well Happy !!
    imported_velcrobix
    Re: S3 Front discs
    I've considered this set up Pal_S3_turbo but i heard that the Tarox G88 discs get through pads really quickley. How are you finding the wear of them?
    S3Steve's Avatar
    Sep 2005
    Peterborough
    1,588
    Re: S3 Front discs
    [ QUOTE ]
    [/ QUOTE ]
    Jabba have started doing a 2piece AP racing setup as a direct replacement for LCR Brembo discs, theyre not cheap but I dont think you would warp these, even on your trackday sessions. [img]/ubbthreads/images/graemlins/groovy.gif[/img]
  28. #27
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,580
    Re: S3 Front discs
    [ QUOTE ]
    [ QUOTE ]
    [/ QUOTE ]
    [/ QUOTE ]
    Is there a pic of these?
  29. #28
    S3Steve's Avatar
    Sep 2005
    Peterborough
    1,588
    Re: S3 Front discs
    There is a pic on their website if you look under Products and then Brakes.
    www.Jabbasport.com
  30. #29
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,580
    Re: S3 Front discs
    Thanks, hmm... 540 inc. vat [img]/ubbthreads/images/graemlins/crazy.gif[/img]
  31. #30
    S3Steve's Avatar
    Sep 2005
    Peterborough
    1,588
    Re: S3 Front discs
    Yeah I said they werent cheap. But AP Racing stuff is excellent quality used by most the topclass race teams in this country. Also remeber for 540 inc vat your not only gettin the disks but also alloy bells and all the mounting bolts. The next time you replaced the disks it would be alot cheaper( just disks).
