Badger5Sky Insurance
Results 1 to 9 of 9
Thread: Random plugs?
    Jan 2014
    south wales
    92
    Random plugs?
    Found these random plugs sitting under my inlet?
    Aug 2012
    47
    Hi, the first image to me looks like a knock sensor connector.
    The second looks like the secondary electric water pump.
    Jan 2014
    south wales
    92
    any advice where to re connect them? been looking around but cant see much
    thanks
    Aug 2012
    47
    Well for the first pic look at the engine block, it should have either one or two sensors.
    For the second one its should be just above the top left corner of the fan.
    Jan 2014
    south wales
    92
    ok thanks had a good look around and cant see nothing lol
    Aug 2012
    47
    Just have the first one connected, don't worry much about the second one.
    Its just under the throttle just under the aluminum manifold.
    U need to remove the throttle using a flat screw driver & an allen key 5.
    Jan 2014
    south wales
    92
    ok thanks maybe my car will run better lol
    Aug 2012
    47
    They don't really change much, according to me.
    Jan 2014
    south wales
    92
    maybe its just 150 bhp aint good enough lol need a remap asap
  1. 1996 A6 2.5TDi Quattro Estate Glow Plug Problem
    By mmarks in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 20th May 2007, 20:13
  2. 2.5Tdi glow plug problem
    By mmarks in forum Diesel forum
    Last Post: 29th February 2004, 20:45
  3. Random, Off the wall Question
    By cbass in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th February 2004, 22:16
  4. 1996 A6 2.5 Tdi Quattro Estate Glow plug problem
    Last Post: 4th December 2003, 19:54
  5. Has anyone removed a plug from the ECU ??
    By batty in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th October 2003, 21:51
