Well for the first pic look at the engine block, it should have either one or two sensors.
For the second one its should be just above the top left corner of the fan.
Just have the first one connected, don't worry much about the second one.
Its just under the throttle just under the aluminum manifold.
U need to remove the throttle using a flat screw driver & an allen key 5.
