EM TuningBadger5
Results 1 to 18 of 18
    Jan 2014
    7
    Angry Newbie with amber oil light sensor
    Hi I have just bought my second mk1 audi a3! (1st one lets not go there) Test drove it, it was fine!
    Got it home and the amber oil sensor light has come on also my car quickly reaches 90* is this normal?
    The service light was on when I test drove it
    s3mad_dude's Avatar
    Noggies ruuuule!
    Jan 2006
    Hampshire
    462
    It could just be the oil level light. Is there a picture of an oil can in amber colour (with the word MIN) underneath it? Anyway, it's worth checking the oil level and topping up if it's low. That's the first thing I'd check. Apart from this, hope you're enjoying your new car.
    Jan 2014
    7
    Hi so I've checked my oil it's fine :-( it's an oil can saying sensor and it's amber? I did ret it with holding the rev counter button turning it on and it's gone off but I haven't driven it.
    s3mad_dude's Avatar
    Noggies ruuuule!
    Jan 2006
    Hampshire
    462
    Ah ok. This is a warning telling you that your oil pressure sensor has a fault. The best thing to do would be to get the car scanned using some software called VCDS to scan your car for any fault codes. Also, you should look into replacing your oil pressure sensor.
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,087
    Its most likely to be the oil level sensor under that car, it plugs into the sump.
    They are about £40-50 from Euro Car Parts, but can be had cheaper, I did mine recently and went OE.
    s3mad_dude's Avatar
    Noggies ruuuule!
    Jan 2006
    Hampshire
    462
    Yes you're right Nilz, I meant the oil level sensor! :-p
    Nilz's Avatar
    Apr 2006
    10,087
    No worries
    Oh and its worth getting it changed sooner rather than later as thats what tells you if you are running low on oil.
    Obviously check the oil level on a daily basis if you cant get round to replacing it straightaway.
    Jan 2014
    7
    Hi so I took it to a garage and the person who had it before me has put the wrong oil in! Have bought all the parts to have it changed and serviced! Hope this works ;-) thanks
    Nilz's Avatar
    Apr 2006
    10,087
    Hmmm thats strange!!
    Do you know what oil was put in??
    Let us know how you get on, oh and as for the temp reaching 90, thats pretty normal, they do warm up fairly quickly, you should be more concerned if it doesnt stay at 90, otherwise its all good
    Jan 2014
    7
    They used 40/15w so getting it changed over thanks for all your help I'll post back if it works ;-(
    s3mad_dude's Avatar
    Noggies ruuuule!
    Jan 2006
    Hampshire
    462
    Fingers crossed
    Nilz's Avatar
    Apr 2006
    10,087
    No worries, im sure you will be fine once its been changed over
    Jan 2014
    7
    Ok so that didn't work so I think I'll need to get a new oil sensor :-( anyone know where I can get one from ?
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    What engine?
    Jan 2014
    7
    1.8 5v ;-)
    Nilz's Avatar
    Apr 2006
    10,087
    Get yourself to Euro Car Parts, they do one in there, i think its about £40 and its a Hella one as well, its just unbranded, so they can sell it cheaper.
    Just give them your reg number and they will be able to get the exact one for you. They do a cheaper one and its upto you if you want to go for this, but with the oil, I wouldnt take the risk.
    Jan 2014
    7
    Ok thanks ;-) right so my other audi that's sat on my drive was trying to sell it but no1 wants to know as the abs light is on :-( had it scanned and they said it is the wiring loom or something is it a quick fix or shall I just cut my loses?
    Also the emissions are bad :-(
    Nilz's Avatar
    Apr 2006
    10,087
    It maybe worth creating a new thread for the other car and abs issues, are you able to get an error or code or anything like that, as that will help alot.
    Any symptoms on the car or issues you experiencing??
  1. Newbie with a head light problem
    By mikeygulley in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th August 2013, 18:53
  2. Oil Light, Pressure, sensor???
    By ben_turbo1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th September 2010, 12:45
  3. yellow oil light & I think 'sensor' next to it
    By 5teve L in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th May 2010, 21:07
  4. Newbie with a strange interior light issue
    By PervyPete in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th April 2009, 12:09
  5. Replies: 1
    Last Post: 17th August 2007, 23:10
