Results 1 to 9 of 9
    Jan 2014
    south wales
    92
    help!!! abs fault code??
    ok so getting this fault on vcds
    Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
    Part No: 1C0 907 379 E
    Component: ESP FRONT MK60 0103
    Coding: 0019970
    Shop #: WSC 06435 000 00000
    VCID: 2C57E2328CAB3A7E18B-517A
    1 Fault Found:
    01423 - Lateral Acceleration Sensor (G200)
    012 - Electrical Fault in Circuit
    i have a light on my dash not abs a triangle with a arrow around it
    any advice would be great
    Oct 2012
    434
    Thats the esp light on, have you tried clearing it to see if it comes back?
    Jan 2014
    south wales
    92
    yes cleared it it just returns straight away the esp button doent do nothing when i press it either
    Oct 2012
    434
    i would start by changing the sensor then
    Jan 2014
    south wales
    92
    May sound stupid but what sensor?
    Spatula's Avatar
    !.8T AGU
    Jan 2013
    North West
    191
    Quote Originally Posted by Audi_A31.8T View Post
    Maybe this one?
    quattrokid's Avatar
    Jan 2006
    Ayrshire Scotland U.K
    220
    I had this with ours ... took a load of nailing it down because we didn't gave any codes !!
    The yellow triangle with the nearly complete circle around it and the ESP light would come on randomly, could be weeks apart !!eventually after changing air maf sensor, abs sensors, even the bloody abs / ESP module was changed,
    The acceleration lateral sensor is about an inch cubed sensor under the dash was the culprit!
    I'm not at home to give you the part number, sorry !
    WR quattro
    B5 RS4
    100 S4 SALOON AUTO
    S3
    Jan 2014
    south wales
    92
    Ok thanks will look into it!vcds gives me part numbers so will check on there!
    epox's Avatar
    Oct 2012
    Glasgow
    599
    part number 1J0907651A could be
    mark
    S3 2003........REVO..........Stage 1...........218G/S.......÷..........°8..........=..........272bhp ......368Nm.....271 ft lbs
  1. New user to vag-com, help on fault codes please
    By Hightower in forum VCDS (formerly VAG-COM) forum
    Last Post: 14th December 2009, 09:04
  2. some help with fault code??
    By mattm in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th March 2008, 19:49
  3. Can you help-vag fault codes?
    By vw754 in forum VCDS (formerly VAG-COM) forum
    Last Post: 27th December 2007, 06:16
  4. Need help with Fault codes please
    By xlr8 in forum VCDS (formerly VAG-COM) forum
    Last Post: 10th August 2007, 22:57
  5. Help with Fault Code
    By madkebab in forum VCDS (formerly VAG-COM) forum
    Last Post: 23rd February 2006, 13:15
