    willh92's Avatar
    Jul 2013
    Portsmouth/Rushden
    136
    Fitting Boost Gauge, which one?
    Hi all,
    I would like to fit a boost gauge to my standard S3, can this be done without having it remapped and it just being standard??
    Also, which gauge would you recommend? I would like it to be vent mounted.
    Will
    S3 - APY silver
    Adam P's Avatar
    May 2012
    Southampton
    321
    Will,
    You can fit a boost gauge without the car being remapped yes. It will just indicate standard bar/psi. Obviously you will get changes on the gauge when the car is remapped. I have a vent mounted boost gauge in a swg motorsport housing unit which has been flocked.
    There are plenty of gauges on ebay which will do the job just have a look around. Here is a pic of mine to give you an idea of what your looking for.
    2001 Audi S3 8L Ming Blue - LOST THE ROD LOTTERY BIG TIME (Rebuild underway)
    willh92's Avatar
    Jul 2013
    Portsmouth/Rushden
    136
    ok cheers mate!
    How do they wire in though, did you do yours yourself? is it a big job?
    S3 - APY silver
    Adam P's Avatar
    May 2012
    Southampton
    321
    Its very simple if you follow a step by step guide, that's what i did. Here is a link :
    VWVortex.com - SW Boost gauge install DIY
    willh92's Avatar
    Jul 2013
    Portsmouth/Rushden
    136
    Cheers mate, I take it you ran the pipe / wiring into the air vent from the grommet in the firewall instead.
    S3 - APY silver
    Adam P's Avatar
    May 2012
    Southampton
    321
    Quote Originally Posted by willh92 View Post
    I didnt have to run the pipewoke through the grommet as my boost gauge came with a valve which sits in the engine bay that the pipwork is directly connected to. This reads the psi and sends the signal back to the boost gauge in the car electrnoically. If you follow the above link for a standard setup you will be fine.
  1. fitting boost gauge to my audi a3 turbo
    By audia3turrbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th October 2013, 20:03
  2. Fitting boost gauge on FL
    By steady jay in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th September 2013, 18:16
  3. Fitting boost gauge
    By motfree in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th January 2011, 00:33
  4. Boost gauge which one??
    By A3_Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th January 2008, 22:36
  5. boost gauge (which pipe)
    By S3 chj in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th December 2007, 16:11
