AH FabricationsChris Nott
Results 1 to 12 of 12
Like Tree2Likes
  • 2 Post By Prawn
Thread: Need more reliable power- S3
    Banana Armour
    Aug 2009
    Leicestershire/Oxfordshire
    171
    Visit aterro's Instagram Channel
    Basically the above.
    Im currently running stage 1 with filter and tip, and in all honesty its not as quick as i hoped.
    ( this isn't down to the cars performance, its performing fine and the engine is perfect)
    ( its due to me getting used to it, and having bigger powered cars)
    If i carnt get the car to a better reliable power, then ill sell up for a e46 M3....
    By "better reliable power" i mean;
    just as reliable as now and quicker haha
    I don't want to do any internal engine modifications, just external mods, e.g. turbo, manifold, fmic etc.
    Id like the car to pull more, and just have more power in all honesty.
    So what are my best options?
    Turbo wise? TFSI turbo? What turbo are these? Or a hybrid straight fit unit to a S3 8L?
    I don't care about figures, just how it responds.
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,283
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    Quote Originally Posted by aterro View Post
    You won't be going above 300bhp/320lbfts if that's the case - and if you do it won't be reliable and will be a ticking time bomb with OEM rods.
    Rods would definitely need to be forged if you want to start talking about hybrid K04s and TFSI conversions and going for a lot more power.
    2000 S3 APY
    18" BBS RSII with Michelin PS3s, 20mm H&R adapters, Relentless 3" DP and Sports cat, B5 V1 induction kit, cone filter+heat shield, Forge 007P, Awesome GTI SMF, AP coilovers, Facelift rear lights, Full Powerflex poly bush kit, R32 Rear ARB, SAI delete, N249 by-pass, Upgraded Engine mounts with Polytek, Stage 1 CC at Badger 5.
    JD09's Avatar
    Dec 2009
    Cheshire, Alderley Edge
    3,080
    Is it definitely running OK? As with a similar setup (map and a B5 TIP) I have 270 ish horse power, which is enough to see off a lot of other road users, ergo plenty fast for now. Useable power I mean.
    The cars are heavy, because of the Quattro. When you say you're use to faster cars, what out of interest? Just wondering if you're like me and have come from "fast" Renaults that feel fast because of their poor build quality, but in real world are slower than the Panzers...!
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    If you are a power hunter An e46 M3 is not for you..they are just too refined, and would soon get bored.
    If you are not prepared to do internal engine work, you are at a stalemate and i would go for something Jap, supra etc....
    JD09's Avatar
    Dec 2009
    3,080
    If you are a power hunter An e46 M3 is not for you..they are just to refined, and would soon get bored.
    Agreed. Or lighter. Cupra R with the same mods would be quicker in gear due to less weight, I presume?
    Banana Armour
    Aug 2009
    171
    so without rods ( i presume they are easy to bend with more power) i carnt really get much more significant power?
    So if i ran a hybrid unit or TFSI turbo;
    id need; (my presumption)
    Forged rods- PEC ETC
    ARP bolts
    Custom map
    Turbo unit itself
    Manifold,down pipe into a exhaust system.
    Bigger injectors and a bigger FPR? ( i don't know what standard FPR reg is)
    i Best get researching then
    RIP S3dave
    May 2004
    nr Glos
    7,187
    rifle drilled forged rods..
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,283
    You can also through in a new clutch, FMIC, and probably either a new in-tank fuel pump and/or an inline pump.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Nov 2013
    109
    Since you're in Leicester you have good people nearby
    Banana Armour
    Aug 2009
    171
    Who would you recommend?
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,377
    The issue here, as I see it, is that without fitting rods, what you actually want is the SMALLEST turbo possible, that is still capable of giving you the power you want.
    Fitting a bigger turbo, then running it at lower boost, may well net you decent bhp, but very low torque due to the low boost, so as a result it won't 'feel' as urgent.
    Running a smaller turbo like the existing ko4 closer to it's limit should still land you just inside the 'safe' rod window, and give you the aggressive kind of power it sounds like you want.
    when I run my ko4-064 (tfsi) at just 1 bar, I get around 300bhp, but only around 260lbft, so it's incredibly linear and smooth, not overly punchy. run at 1.5 bar it produces almost another 100lbft, and feels incredibly punchy, but of course, you're into 350bhp+ power at that point and in desperate need of rods.
    If you want to keep it stock internally, I'd suggest a decent compliment of st2 mods with the ko4.
    if you want more, fit rods, and the tfsi k04 and associated parts, it's truly fantastic
    Westy and flying oyster like this.
    Nov 2013
    109
    Rtech and Badger5 are highly recommended VAG tuners in the UK, rtech are in leicester and the badger set is near Gloucester
  1. I need More Power! Any ideas?
    By Fastdrx in forum Diesel forum
    Last Post: 11th May 2009, 00:55
  2. 2.0L Needs more power!
    By AudiSport in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th April 2007, 17:47
  3. NEED MORE POWER!!!!!!!!!
    By deedus in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st February 2007, 10:11
  4. Need more power?
    By simonelman in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th July 2005, 18:01
  5. Dammit I need more power!!!
    By AlexStanley in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th March 2003, 11:47
