Chris NottSky Insurance
Results 1 to 9 of 9
Thread: Dogbone mount
    ben_harmer32's Avatar
    Jul 2013
    90
    Dogbone mount
    Went to the garage today to have my dogbone mount changed as there's a bang/clunk when I change gears. Garage started to do it but when undoing the middle bolt it started leaking gearbox oil.
    is this normal?
    Garage said aid they would ony do it if they fully drained the gearbox first, so gave up for the day and left.
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    899
    Add Vex182 on Facebook
    Not at all, it's got nothing to do with the gearbox oil. I can't see why that is happening from a dogbone change.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,607
    Nopes... its not normal...
    <tuffty/>
    May 2013
    Birmingham
    212
    That is very odd it's a 15 minute job if it's on ramps!
    Jul 2013
    90
    Fluid was dripping out when undoing the middle bolt. Is it possible if the gearbox oil was spilt when filling it might of collected behind somehow?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,607
    Had to check as this was niggling me... the dog bone bolts to the bell housing not anywhere near the internals of the box... the oil is not coming from there...
    Here is one I did earlier
    <tuffty/>
    Jul 2013
    90
    Very odd then, time to go to audi i guess....
    Just so we are clear it's this bolt that is leaking:
    Sep 2006
    Sunny Suffolk
    554
    Sorry, small hijack. tuffty, is that purple bush the powerflex one? If so, could you say whether that bush in particular emphasises cabin vibrations? Going to fit the red (in your case yellow) bush, but in two minds over the purple bush. Any experience with the superpro equivalent?
    <hijack/>
    Oct 2013
    in the middle
    114
    oh dear, not good
    just checked on my spare box, that bolt hole goes all the way through the bell houisng, so any fluid collecting in there will come out when you undo
    it could be two things
    gearbox oil, leaky input shaft seal in gearbox
    engine oil, leaky rear main seal
    both are gearbox out jobbies and possible new clutch plate
  1. Anyone have a spare dogbone mount?
    By themanthatcan in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th March 2009, 19:53
  2. Dogbone Mount
    By neil20vt in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd August 2007, 17:42
  3. S3 Dogbone mount
    By Buster in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th October 2006, 19:05
  4. dogbone mount.
    By millsyd in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th August 2006, 16:01
  5. EIP Dogbone mounts
    By richy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th August 2005, 14:47
