Sky InsuranceAH Fabrications
Results 1 to 11 of 11
    willh92's Avatar
    Jul 2013
    Portsmouth/Rushden
    156
    Draining coolant and refilling, How to?
    I'm looking to drain the coolant out of my '99 S3.
    How would I go about doing so, anyone got a step by step? Likewise for refilling?
    or what is the best point to drain it out from?
    cheers
    will
    S3 - APY silver
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    There is a drain valve at the bottom of the radiator, fill slowly with heaters on hot and full squeezing bottom rad pipes as you go..
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,578
    The tap on the rad will only part drain the system...
    Coolant change . (how to)?
    <tuffty/>
    willh92's Avatar
    Jul 2013
    Portsmouth/Rushden
    156
    Cheers tuffty, good guide there.
    How do you bleed the system?
    Also, does refilling the system from the header tank fill the radiators up if the drain point is on the rad? Cos on some things I've had to fill the rad first then from the tank.
    S3 - APY silver
    May 2013
    Birmingham
    212
    I had no problem refilling from the header tank just kept the heaters on and squeezing the pipes.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,578
    When doing rods and head swaps etc on 20v's I normally drain from the rad tap then drain out the back of the block...
    Use new OE banjo sealing washers for the turbo line once drained and then fill through the expansion bottle...
    Once the level in the tank has reached the point its not draining down I normally leave the engine idling for a while with the expansion tank cap removed topping up as required......
    Be aware the coolant level will rise a bit as the temp increases but you need to get to a point that the stat opens to ensure the system is filling
    <tuffty/>
    JD09's Avatar
    Dec 2009
    Cheshire, Alderley Edge
    3,080
    Is that in the stickies, Paul? As might be an idea to add if not
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,470
    <tuffty/>
    this is what he means
    Always bleed your coolant system properly+check it when its cold.. Warning skin burns
    RIP S3dave/David Marshall stickers now available
    FOR SALE
    None resonated Milltek exhaust,
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts, relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,578
    Quote Originally Posted by Andrew@A.L.D View Post
    Good point... this is what happens if you are not 'paying attention' (shall we say )
    Never had an issue like this running the engine with the cap off BUT.... you can't leave it... I always keep an eye on it and NEVER undo a cap on a hot engine... let the engine cool down a bit first then slowly undo the cap to release the pressure whilst keeping an eye on the level in the expansion tank... if it rises as you undo then tighten back a turn or two and move away....
    Its a bit like undo a pop bottle thats been shaken only coolant WILL strip your skin... (as demonstrated by the lovely Andrew)...
    Not a good place to be (hope its healing ok mate)
    <tuffty/>
    Jun 2009
    Leeds
    3,470
    Yes unexpected air lock in the coolant system and rushing was my fault that i was injured
    FOR SALE
    s33nyboy12's Avatar
    May 2012
    East midlands
    1,386
    This is my how too!
    LEGEN..............Wait for it ..........DARY
    Sean
    Current: 2013 Audi A3 2.0 tdi s line 8V in black SD nav+ extras, E46 BMW M3, 1971 Volvo p1800, 2014 Ford transit sport 155ps ;-)
    Previous : Focus st 225 stage 1 (265 bhp and too much torque), 2002 audi s3 bam engine completely OEM, 2001 Audi a3 1.8 TQS 221bhp and about 20 other cars, majority civics ek4/ek9 and Bmw / Audi soot chucker's!
  1. Intermittent fault with coolant and engine management system
    By clarebear in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th December 2009, 15:45
  2. And another how much are they worth
    By JohnboyC in forum General Chat
    Last Post: 3rd May 2009, 20:08
  3. coolant and ignition
    By g00dd0ct0r in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th March 2009, 09:03
  4. ...and heres how it SHOULD be done!
    By 28v6 in forum General Chat
    Last Post: 10th March 2007, 08:13
  5. Coolant and Haldex servicing and anything else ?
    By A3_TOBES in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th November 2006, 13:08
