EM TuningJMB Retrofits
Results 1 to 15 of 15
    ben_harmer32's Avatar
    Jul 2013
    90
    S3 Uprated Coilpacks
    Does anyone make uprated coilpacks for the S3 (1999)?
    Remember upgrading on my skyline and it made a huge difference.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,602
    There is an 'upgraded' one apparently, silly expensive and largely pointless...
    There was also a huge thing about TFSI coilpacks too which is mostly rubbish too...
    There is a TFSI coilpack thread in the FAQs
    I have been running TFSI coils for a little while they made no difference to anything other than making my pocket lighter... even running the 1mm gaps did nothing measurable on the dyno...
    TFSI coils look good if you use the expensive alloy adaptors (or just as good with the the OE plastic ones) but they work no better than a new set of 20v ones IMO...
    I've not yet managed to blow the spark out with 2bar and a GT3071 and TFSI coil packs still fail like 20v ones so the choice is purely cosmetic...
    <tuffty/>
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,602
    Okada is the brand from what I have found out and are like £100 or more each... vs 30 quid each for OE
    <tuffty/>
    sssline's Avatar
    Apr 2012
    Essex/London
    135
    I'd second what tuffty has said about TFSI coil pack, when I spoke with Badger5 he told me much the same so no point going to extra cost when unproven.
    Tuffty do you know if the TFSI coil pack lasts longer? I've read this somewhere recently...
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,602
    Quote Originally Posted by sssline View Post
    Not sure that any of them are any better than each other tbh mate... I am using 07K 905 715 F
    <tuffty/>
    Jul 2013
    90
    Cheers guys.
    So is it worth getting replacement standard ones and colder grade plugs instead?
    Car has been mapper and has exhaust, filter etc..
    Jul 2011
    Berkshire, Surry, Hampshire tri-intersect
    444
    also if you still have OE coil packs its worth remembering that they are on recall and you may be able to get them all swapped out for free...
    Jul 2013
    90
    How do I know if I have OE ones?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,602
    Quote Originally Posted by ben_harmer32 View Post
    Should mention at this point that you have an APY engine code so these will be bolt down coils... they will have the 4 ring logo and hitachi (beru on the latest revision) embossed on them..
    Bolt down OE packs are generally regarded as being more reliable than push down types... but like anything they do degrade over time and you will always benefit from new replacements... however pattern part coils are generally rubbish...
    TFSI coils (push down) can be made to fit APY cam covers using either the pricey alloy adaptors or the amazingly cheap OE adaptors...
    <tuffty/>
    mattyboy199's Avatar
    Nov 2005
    UK
    1,689
    TFSI coils are cheaper by about £40 a set.....so if you need replacements its makes sense plus if you have a BAM engine car you don't have to run adapters it just makes it look more pleasant.
    2002 Dolphin grey S3 - Sym2+bose, heated leather, ally mirrors, R32 ARB's with superpro, Jabba stage 2 map, TFSI coils, Samco TIP, Forge DV & privacy glass
    2010 Green Kawasaki Ninja ZX6R - Akrapovic baffleless race can, LED cluster & HID's
    wanted for 8L S3:
    Unmarked grey rear bumper panel
    Milltek system
    bigray's Avatar
    Oct 2013
    leeds
    147
    don't audi do a new coil pack ? as it re call part ?
    or is that just replace old with new ?
    sssline's Avatar
    Apr 2012
    Essex/London
    135
    Quote Originally Posted by mattyboy199 View Post
    So they're straight swap? Didn't know that...
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,602
    Sorta... TFSI coils stick out further
    2.0 TFSI Coil Packs on a 1.8T
    <tuffty/>
    sssline's Avatar
    Apr 2012
    Essex/London
    135
    I read that thread. Oem plus is what I'm aiming for in general. No point going to extra cost when there's so much else to spend on.
    Feb 2006
    Lincolnshire
    722
    I know the general consensus is to avoid aftermarket coil packs, but I purchased 4 brand new BERU branded packs from GSF about 20 months ago (circa £80 for the set with a discount code, normal price £100ish for four) and they haven't missed a beat.
    They do some cheaper ones too, as well as OEM ones that are more pricey than from TPS etc, but it was late on a Saturday and nowhere else was open etc.
    I believe BERU make coil packs for VAG now anyway.
    Audi S3 - 2002MY - Denim Blue - Gone
    VW Polo GTI - 2011MY - Candy White - Here
  1. Star Performance Testing Day Pt6 Uprated Brakes
    By Ess_Three in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th February 2011, 15:06
  2. Uprated Clutch & Flywheel ?
    By RAPS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th March 2004, 19:48
  3. Uprated Brake Pads
    By nicks3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th December 2003, 16:51
  4. Coilpack question
    By AlexStanley in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th November 2003, 16:00
  5. Help! Need a new coilpack!
    By SteveS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd January 2003, 22:29
