Monster MotorsportEM Tuning
Results 1 to 36 of 36
    Nov 2011
    Leeds, UK
    287
    Are all MK1 TT and S3 driveshafts the same?
    Before I pull the trigger on one on ebay!
    I need a new gaiter and a new inner CV joint, so seems easier to just buy a complete used driveshaft for now.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    Not exactly no... the 'shaft' is but the joints aren't... early ones uses a nut to secure the outer CV to the hub, later ones use a bolt... I believe the hubs are different too (not really paid too much attention to one to confirm) as the bolt type have a tapered seat
    <tuffty/>
    Nov 2011
    Leeds, UK
    287
    ********! So how can I tell if a TT one is right, visually? Or if an S3 one is the correct type?
    Nov 2011
    Leeds, UK
    287
    Just been on something call VagCat and found more than one part number listed for the APY S3 front driveshaft
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    Will be fairly obvious...
    Here is a pic of mine... I have the bolt type... its identified by the 17mm allen key type end...
    The other tyoe has a nut instead so the end has a threaded bit on it
    <tuffty/>
    Nov 2011
    Leeds, UK
    287
    Been outside to have a look and mine look as though the driver side is much thicker than the passenger side. Is that normal?
    Right, as far as the ends go, because I have no centre caps on the wheels just now, I can see they are attached to the hub via a large nut and just have a circular indent in the very middle. No big hex fitting.
    Which part number would these be?
    Nov 2011
    Leeds, UK
    287
    So this one, the part number isn't listed for my car, APY S3, but it's a threaded end and from a MK1 TT??
    AUDI TT MK1,S3 QUATTRO DRIVERS SIDE FRONT DRIVE SHAFT ,O/S 1J0 407 272 FL | eBay
    According to this:
    AUDI A3/S3/SPORTBACK/QU. [A3] (EUROPE) 1999: FRONT AXLE, STEERING: 40722. DRIVE SHAFT
    Any views so that I can buy one?
    Nov 2011
    Leeds, UK
    287
    I'm just getting myself wound up and more confused now.
    Part number 1J0 407 272 FL doesn't show ont hat catalogue, but it does say:
    1J0407452LX drive shaft with constant. drive shaft with constant; velocity joints; to use for:; right; 1J0 407 272 FQ; AJQ,APY,AMK,; AUL
    Almost the same part number but FL instead of FQ? Is it possible FQ superseded FL and so they don't mention FL in their text now?
    Very close to buying, just scared to make a mistake
    EDIT: ECP sell this for just £63! Surely it would last at least a year? Or are they utter crap and I'm better off buying used OEM?
    ECP part number: 654445201
    A3 TQS
    Jul 2013
    Devon
    168
    The software I use only shows one for your engine code? the fl/fq numbers your quoting are old and superseeded by the numbers on the left.
    The same seller you linked to has an FQ aswell AUDI TT MK1,S3 1.8T QUATTRO DRIVERS SIDE FRONT DRIVE SHAFT 1J0407272FQ ,O/S/F | eBay
    Nov 2011
    Leeds, UK
    287
    He does, but it appears to be a bolt type, not a nut type.
    A3 TQS
    Jul 2013
    Devon
    168
    Ahh yes, in that case I don't know can be a bit of a minefield finding the correct parts sometimes!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    Personally I would just be buying a new CKN branded or OE inner joint kit from ECP/GSF or Dealer/TPS...
    The cheaper joints don't really last and the boots less so... especially when running more than std power
    Pattern part longevity will be subjective, OE/decent brand will be predictable
    <tuffty/>
    Nov 2011
    Leeds, UK
    287
    To be honest, I normally would, but I had a bad experience once trying to change a joint. It just wouldn't come off the shaft, no matter what I did.
    That was on an old Impreza.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    Quote Originally Posted by Bad Sir Culation View Post
    Driveshaft gaiter replacement tutorial
    <tuffty/>
    Nov 2011
    Leeds, UK
    287
    Legend. Looks like my only option brand new is £75 from GSF though...
    Nov 2011
    Leeds, UK
    287
    Contacted GSF, the only front inner CV they do is branded GSP??
    They do a GKN rear but that's it. I'm not sure about paying 75 notes for some brand I've never heard of....
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    Give a dealer or TPS a ring dude...
    <tuffty/>
    Nov 2011
    Leeds, UK
    287
    Tps are very expensive, and a dealer usually is too, but I'll give them a try.
    Nov 2011
    Leeds, UK
    287
    Rang both. TPS asked me if it was a plastic boot or rubber. Their price is £98 plus £12 surcharge as it's an exchange part.
    Dealer told me plastic boot superseded rubber and it's £128 after vat and with the exchange part.
    Jeez....
    Nov 2011
    Leeds, UK
    287
    So the options as I see it are thus:
    Q-drive full new driveshaft with two new joints from ECP, £63. - Not really what I'd choose if money weren't tight.
    Brand new GSP inner joint from GSF for £75. - Heard bad things about these.
    Used driveshaft and joints from EBay, £40. - Might be wrong one. Might last two weeks, but very cheap.
    Need to decide which of these is my best way forward.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    Appreciate its a tough call dude... guess it depends on future plans for the car and how long you anticipate keeping her... obviously for me I'd go OE or GKN...
    Without looking at ETKA to check I believe that the 02M joints are pretty much all the same and the part number differences are more likely for shaft length as I have a feeling 02M equipped 8L's differ depending on if its AWD or FWD (the longer fatter shaft will change here) and if its a cast arm (TT/S3... not sure if the 180 TT FWD got the cast arms) or the pressed steel ones
    Worst case is that you can use the inboard joint from the second hand shaft to get you going again...
    <tuffty/>
    Nov 2011
    Leeds, UK
    287
    Cheers. Leaning towards the new Q-drive at the moment. Not ideal but hey Ho.
    Only worry there is whether the driveshafts are sided. They do look different to me, but nothing on ECP says anything about it.
    Nov 2011
    Leeds, UK
    287
    From what I can gather, I have the early front arms with smaller bushes.
    Also, what's 02M? Gearbox code?
    A3 TQS
    Jul 2013
    Devon
    168
    Yes 02M denotes the gearbox type, then theirs usually 3 other letters which determine the ratios inside box.
    Nov 2011
    Leeds, UK
    287
    My brain is fried, trying to decide this in time to have the parts tomorrow.
    EBay guy says his driveshaft will fit so I guess that gives me a leg to stand on if I buy and it doesn't. I'm now thinking buy that, try it, strip back the boots and service the joints, job done.
    How long should a CV joint really last?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    I see what you mean... they only list one shaft but don't ellude to which side it is (other than measuring its length)
    Found these... they have 100% on than an 80k feedback score so suggests they should be ok as a seller...
    AUDI S3 QUATTRO 1.8 TURBO PETROL DRIVESHAFT & CV JOINT NEAR/SIDE 1999 2001 | eBay
    AUDI S3 QUATTRO 1.8 TURBO PETROL DRIVESHAFT & CV JOINT OFF/SIDE 1999 2001 | eBay
    Brand new and says 2yr warranty
    <tuffty/>
  28. #27
    Nov 2011
    Leeds, UK
    287
    Sure someone on here said they used then and they weren't great. Might have been a post from JimS3 I saw.... I did see these you see and searched them earlier. Apparently they weren't great but they refunded him no probs.....
  29. #28
    Nov 2011
    Leeds, UK
    287
    Screw it, I think I'll try it.
    Cheers dude.
    Just out of interest, should I be looking to do the other side too? Concerned about some kind of balance being disturbed.
  30. #29
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    Well... this brings the discussion full circle I reckon and leaves you (IMO) with the following choices...
    Buy a genuine joint from TPS happy knowing its the correct part and won't break
    Buy a secondhand shaft on the chance its not too worn, may or may not fit the car and that you may have to return it if no good or strip it down to just use the one joint if its not quite right fitment wise
    Buy a pattern shaft hoping it will last more than five mins...
    The old adage buy cheap buy twice probably applies here... for what its worth I used a pattern gaiter for the tutorial I linked you too above... it had lasted 6 months before cracking and binning grease everywhere... it was replaced with a used OE one that in itself has been fine but I had to use the metal piece from teh pattern part and it pops off every now and then (as seen in the pic below)
    This will be replaced with a genuine one before the engine goes back in
    <tuffty/>
  31. #30
    Nov 2011
    Leeds, UK
    287
    That's a fair point and to be frank, one I believe in very firmly after buying a "cheap S3"!
    But there are two things at work here, I'm fitting new shocks and bushes before the end of the month, and don't want to pay for 2 alignments.
    I don't have much spare cash with all these parts I need to buy together, and I don't get paid properly until the end of March (don't ask).
    Then we have the Mrs... She suffers a chronic joint and muscle pain condition and is currently finding being back in a manual quite difficult on her back and hip at the minute, so despite all my hard work, the car may very well be up for sale once we get a full MOT on it around May.
    So it's certainly a balancing act for me here. It's either pattern part with warranty or it's used part and give it a service.
  32. #31
    Nov 2011
    Leeds, UK
    287
    I've bought one of those J and R ones. Let's hope it doesn't create any balance issues!
  33. #32
    A3 TQS
    Jul 2013
    Devon
    168
    Hope it all works out for you
  34. #33
    Nov 2011
    Leeds, UK
    287
    Cheers matey. Bought some Powerflex RTABs today too
  35. #34
    Apr 2012
    98
    i have had a pair of J&R one on for a few weeks, nothing bad to report yet
  36. #35
    Nov 2011
    Leeds, UK
    287
    Cheers for that, makes me happier!
    I might go ahead and replace the other side too just for my own peace of mind and to make sure it's all matched. Will wait to see what this one is like first.
  37. #36
    Nov 2013
    Hi All,
    I'm new to this forum and S3 ownership... I have owed a few Audi's in the past... most recent being a 90 Quattro but that was some years ago now.
    Anyway, I'm hoping you guys can help me... I've looked at the excellent tutorial by Tuffty and my boots appear to be the same as his.
    My car is a 2000 S3 with APY engine and built date 12/99.
    I'm just wanting to confirm the part number for the boots... I already bought some from ECP... the outers look ok but the inners are definitely not going to work... the upper diameter is too large. I spoke to them again and they now advise different parts for both inner and outer... the outers seem almost identical to what they already supplied and the inners don't really look like the ones fitted to my car so I don't really have confidence in what they are telling me.
    Superkarl and Bazil both posted that they used 1J0 498 201E for their inners... however, this part does not look like my inners nor like Tuffty's.
    Mine look most like 8N0-498-201-A as seen here:
    2000 Audi TT Quattro Base Coupe - Axles, Bearings & Differential - Page 1
    I don't really want to pay for another set and shipping (I'm in Sydney so it's not cheap) if they are not correct if I can avoid it.
    The part numbers on my actual axle shafts are:
    Driver's side (RHS) is: 8N0 407 272 E
    Passenger side (LHS) is: 1J0 407 271 FD
    So I'm wondering if Tuffty or somebody may be able to chime in with some advice as to whether 8N0-498-201-A is the correct part... the GKN Loebro catalogue seemed to suggest it is the correct part but it was inconclusive.
    Thanks in advance for any help and I look forward to being part of your Forum... I've had a bit of a look around and it looks like you have a very nice Forum with lots of good information.
    Kind regards,
    Geneqco
  1. are mk4 4 motin and audi tt the same coilovers
    By dancupra225 in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th June 2012, 22:19
  2. are an s3 silver and a3 silver the same colours?
    By marshall-12 in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th June 2012, 17:37
  3. are a6 and a4 springs the same
    By audi-a6 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 7th February 2012, 12:54
  4. ?? are Manual and Dsg engines the same ??
    By shah786 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th April 2009, 15:18
  5. avant and saloon coilovers the same???
    By M22_PRE in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th February 2008, 21:36
