AH FabricationsChris Nott
    AVLO's Avatar
    Mar 2012
    Doncaster
    255
    strange engine noise/knocking :-(
    Hi guys
    I seem to have a small issue with my car, whilst im stood stationary I seen to get a knocking noise from the engine area that varys between every 5-15 seconds. When I hear the knock I can also feel it through the footwell it nearly seems like some sort of mechanical component knocking. If I rev the car up to 2,000rpm and hold it there for 10seconds and let off you can hear a vibrating noise and when the idle settles the knocking becomes more apparent (louder) for a short while then resides to the slight knocking I can feel. Has anybody else ever had a problem like this?
    Im not sure if it is clutch/flywheel related or engine internal related?
    Im worried that when I accelerate something is going to go pop :-(
    Matt
    BRING ON THE WET WEATHER ​QUATTRO FTW
    mark_S3's Avatar
    Yorkshire & Humber Events Mod
    Sep 2012
    Wakefield
    494
    A problem Matt?
    Must be catching upto me with the never ending problems ;-)
    Sorry can't help you pal. Although it sounds like flywheel/clutch related.
    If you depress clutch and rev it to 2,000rpm does it still do it? And same outta gear?
    ***2000 Audi S3 8L APY***
    * Milltek CATback * Milltek 200 Supercell Sports CAT * SuperChips SRP Stage 1 Remap * Forge 008p *
    * 18" Audi TT 240 Sports Alloys in Gunmetal Grey * Pagid Discs with BD Predator Pads *
    * Badger5 v2.2 TIP, Jetex Filter with Heatshield * N249 Delete * N112 Bypass *
    * PowerFlex ARB Bushes *
    ~ Soon to be fitted: s3dave Adjustable Control Arms ~
    http://www.audi-sport.net/vb/signatu...pic65622_5.gif
    AVLO's Avatar
    Mar 2012
    Doncaster
    255
    I havent tried it with the clutch depressed but it is out of gear and idling whilst its doing it. In gear acceleration seems fine. Im wondering if it could be the DMF
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    Sounds DMF related..
    AVLO's Avatar
    Mar 2012
    Doncaster
    255
    Is there anyway of checking if its the DMF without stripping gearbox and clutch off? Or is it a case of waiting till it gets worse?
    Oct 2013
    East Sussex
    208
    I would say it's Dmf too, can't know for sure unless you strip gearbox and that can be pricey, so you are best off, getting them both replaced.
  1. strange whistling noise from s3 engine bay
    By gaz24s3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th January 2014, 22:56
  2. Strange engine noise
    By Marlonlaight in forum A5/S5/RS5 Forum
    Last Post: 21st August 2013, 20:32
  3. Strange Engine Noise
    By stephanroos in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th March 2010, 00:57
  4. Strange 'Jet Engine' noise on first start up...
    By spuddie007 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd January 2008, 21:43
  5. Strange S3 noise from engine
    By showyS3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th July 2007, 08:09
