Chris NottAH Fabrications
Page 2 of 2 FirstFirst 12
Results 41 to 51 of 51
Like Tree1Likes
Thread: MASSIVE problems with my Sport
  1. #41
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,553
    Good luck
    Just don't rush in cutting all the wires at once... be a lot easier that way
    <tuffty/>
  3. #42
    Nov 2013
    Nottingham Derby
    110
    Now that's just plain old mean Tuffty, 'liking' the fact I've got to undo spaghetti junction . ....In the rain aswel with the look of it
    I'm hoping to take it all the way back to the ECU Plug Do you just take the other Plug's off the Harness or can they be used aswel? Not sure where their for!?
    My 1st double page Thread on here
    I thought I'd have a read through your Build Thread earlier I got to page 20, thought I'd cheat as I wanted to see some vid's, so skipped to the last PAGE '62'!!!!!!!!!!!! Only to find a completely different set up haha haha hahaha So I think I'm just going to have to read the other 45 pages hey!!!!!!!!!
    Do you see anything 'interesting' in the Log's?!
  4. #43
    Nov 2013
    Nottingham Derby
    110
    So, replacing the Coil Pack Harness!!!!!!!!!!!
    Attachment 26506
  5. #44
    Nov 2013
    Nottingham Derby
    110
    I have a split in the Y Piece of the PCV Hose. These Wires run underneith there & were covered in Oil! It had got inside the Conduit & had actually worked it's way underneith the Insalation Tape aswel!
    Attachment 26507
  6. #45
    Nov 2013
    Nottingham Derby
    110
    Then things got better, when I removed the Plug from the ECU I noticed 2 of the Holes looked like they had 'rust' inside
  7. #46
    May 2012
    RETFORD, NOTTS
    1,753
    You'll probably need to re pin that plug.
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
  8. #47
    Nov 2013
    Nottingham Derby
    110
    Oh look, there's a swimming pool inside my ECU Plug Socket!!! This is the part that's actually connected to the ECU itself. You can also see moisture droplets on the back part & the discoloured Pin's
    Attachment 26509
  9. #48
    Nov 2013
    Nottingham Derby
    110
    This is the Plug from under the Battery Tray. Also with moisture in it & defintely corroding 1 of the Pin's! All Seal's etc on these Plug's look perfect & still 'popped' from suction when pulled apart
    Attachment 26510
  10. #49
    Nov 2013
    Nottingham Derby
    110
    Once I'd got right into the ECU Plug I found out just how bad things are!!! Somehow, as if my majic, there's gritty water right down into the very inside of the Plug Terminals
  11. #50
    Nov 2013
    Nottingham Derby
    110
    Even without the Coil Pack part of the Harness with the usual split's etc this has to have a lot to do with my problem's!! I've not Jetwashed the Car or anything so the only thing that could of caused this is just rain & the water from the Window Wipers getting into what must be the most stupid place to put an ECU!!
  12. #51
    Nov 2007
    Bl**dy hell mate - that's a sod and a half !
  1. Problems with my Audi A3 1.8T Sport 2000
    By jogonpc in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd January 2014, 19:25
  2. Replies: 0
    Last Post: 16th June 2011, 19:08
  3. Problems with A4 T Sport Quattro
    By rack1 in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th January 2004, 10:49
  4. Problem with alarm
    By tim in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd April 2003, 12:58
  5. Problems with alarm transmitter.
    By DJG in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th January 2003, 08:23
