Chris NottSky Insurance
Thread: DIS in an R reg
    easytease's Avatar
    cheesypeas
    Nov 2005
    england, surrey
    426
    DIS in an R reg
    a friend has a R reg 19tdi SE, which he only brought on friday. its a lovely motor. but he doesnt hav ethe DIS thing that i have in my 1999/2000 A4 SE, which is what he wanted so he can kep an eye on the mpg etc. anyone have any ideas if it can be jimmy rigged in?
    easytease's Avatar
    cheesypeas
    Nov 2005
    england, surrey
    426
    Re: DIS in an R reg
    can nobody help then?
    MikeA3's Avatar
    Mar 2005
    Epsom
    1,176
    Re: DIS in an R reg
    I think DIS may have been an optional extra on the A3's in 99.
    I've not heard of anyone retro-fitting it due to the sensors required etc although i'm sure it's possible if you have the time & money.
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Re: DIS in an R reg
    As far as I know the inputs are there. You would need adapt the unit to the ECU and key reader and keys as the clocks contain the immobiliser. You can do this with VAG-COM if you know your SKC (secret key code) which is under the black scratch off panel on the Audi key fob. If you don't have the code then you must get audi to perform the swap as they don't issue these codes.
    Khufu's Avatar
    West coast of Scotland
    5,693
    Re: DIS in an R reg
    I looked into it. Lots of rewiring too do as none of it is there at all plus as HTC says the DIS equipped Cluster will need to be coded to your ECU. Not impossible but pricy if you dont do all the work yourself.
