Results 1 to 13 of 13
Like Tree2Likes
  • 2 Post By eightfour7two
Thread: Looking for a after market headunit what do you recommend
    Dec 2013
    Letchworth Garden city
    41
    basically I'm after a new head unit that can play my iPod, has at least a 6'' screen and if possible has the ability for android phone connectivity and sat nav but not essential. and obviously as little cost as possible.
    Aug 2011
    Plymouth
    614
    Add Lavis89 on Facebook
    rather than putting a whole new head unit it i bought a aux adaptor for my existing one, use a cheap ebay phone holder on my dash and just use my phone for satnav, music, anything basically
    2001 1.8T Quattro Sport 89k covered ARY engine.
    Remapped at Badger 5, 213bhp - 235lb/ft torque.
    HS2K cone, FMDV008, Silicon TIP, 18" RS4 (reps), AP coilovers, Catch can, n249 bypass, Toyosport 3" Downpipe/Decat, S3 Front brakes, Polyflexed Dogbone, S3dave adjustable tie bars
    Soon to be done: SAI delete, Install the toyosport FMIC i have kicking about in my living room
    nicksthebiz's Avatar
    Nov 2012
    Hayle, Cornwall, UK
    115
    Not got a screen or cd player but cheap with full support for andriod + ipod Pioneer MVH-350BT
    also red matches interior ambient lighting of red... well its pretty dam close
    Nick Jones
    Cornwall
    nicksthebiz@hotmail.com
    1.8T S3 8L APY 2000
    s3mad_dude's Avatar
    Noggies ruuuule!
    Jan 2006
    Hampshire
    458
    If you're running the Bose setup it's not just a simple plug/play job. There's all sorts of adapters and weird shizzle you need to install too - just a heads up.
    Nov 2012
    Hayle, Cornwall, UK
    115
    yes i did have a couple of issues with the different cables /Adaptors that halfords sell got there eventually tho
    Nick Jones
    Cornwall
    1.8T S3 8L APY 2000
    Jay A3's Avatar
    come fly with me
    Mar 2011
    Greenhithe, Kent
    1,698
    Search for app radios. Ie pioneer da100 or da110
    <Jay A3 build thread>
    241bhp K03s - R Tech
    Dec 2009
    Herts
    54
    Quote Originally Posted by s3mad_dude View Post
    did u do this to yours at all?
    Dec 2011
    Somerset
    304
    Quote Originally Posted by Jay A3 View Post
    Not good reviews about these on Amazon.
    eightfour7two's Avatar
    Sep 2013
    Swansea
    27
    I went through all the rigmarole of putting an aftermarket HU in my S3 a few months ago; in the end I decided it wasn't worth it and went back to the stock HU (Chorus II, with a tape deck!) and a Connects2 box behind the dash to handle iPod/Aux inputs.
    For the aftermarket HU, you'll want to make sure you get one with dual (front+rear) pre-outs on the back, that way you can use the Autoleads PC9-408 to connect to the Bose system, far better than using that high-to-low converter lead. There are a few problems however: You'll need to run an ignition live from the fusebox to the HU because the stereo won't know to turn off when you take the key out of the ignition. Also you'll probably get loud pops from the speakers when turning the HU on and off, although that can be fixed by fitting ground-loop isolators between the pre-out and the wiring harness.
    All in all, it's far easier to use the stock head unit (no popping, turns off and on with the ignition) and use a box in the dash to handle aux/iPod/bluetooth
    JoeeS3's Avatar
    Apr 2013
    Cardiff
    302
    Follow JoeeS3 On Twitter Visit JoeeS3's Instagram Channel
    if you want a bose wiring loom from halford you can have mine for £35 i only bought it two weeks ago but my double din didnt work well with my phone so i got rid of it. i believe it is the PC9-408 loom, £45 brand new
    i'm not a genius...i'm a learner
    May 2013
    Channel Islands, Jersey
    68
    Quote Originally Posted by eightfour7two View Post
    Hello mate,
    Can you explain this a little more to me, or send a link/guide that tells me what to do. Looking at the easiest and best way to play iphone / ipod music.
    I appreciate any help.
    J
    Audi S3 AMK, Badger 5 Tip with Cone and Heat Shield, Forge 007P (green spring), de-cat pipe
    Sep 2013
    Swansea
    27
    Well mine was a Connects2, which you can find here, just find the 'iPod adapter' section. You basically connect the box up to the CD changer port on the back of your original head unit and run an aux or iPod cable from that box. I routed my aux wire so it comes out from under the glovebox
    sssline and Jersey like this.
    Nov 2012
    Hayle, Cornwall, UK
    115
    i put the pioneer head unit in usihg a loom adaptor from halfords it was ahit fiddly but i found one that works and i do have a bose system... but i did get a popping /interferance over the speakers. i then fitted a sub in the boot from the sub out on the backmof the HU andmi un plugged the oem/stock subs in the rear left of the boot this stopped the interferance so i now have all speakers working other than the stock subs in the rear left of the boot and a aftermarket sub in the boot ...
    this set up is ok but the speakers are not perfect with the sub, the bass from the sub on some songs over powers the bose system speakers
    Nick Jones
    Cornwall
    1.8T S3 8L APY 2000
  1. Looking for a after market headunit what do you recommend
    By fazer0 in forum In-Car Entertainment
    Last Post: 17th January 2014, 00:38
  2. After market headunit/non bose system - will PC9-408 do for me?
    By Shane-Ireland in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th June 2012, 18:27
  3. Replies: 4
    Last Post: 17th November 2010, 00:15
  4. After market headunits and rear parking sensors
    By L e o in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th February 2010, 20:40
  5. Crashed with after market wheels - what will Audi say?
    By silverlogic in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th January 2010, 12:43
