removing actuator k04
m19lte
greater mcr
Evening all. I'm having boost issue's and am going to be removing my actuator. Question is how to get the actuator off ? Doe's anyone have any info or picture's ? I can't find his to remove/fit one in the searches. Thanks - 8l s3 k04-023
Very easy on a ko4-02x, you have the 2 10mm nuts on the threaded bar part (remove the outer nut) and 2 10mm bolts holding the actuator bracket to the compressor housing. That's it.
Remove the upper charge pipe and it all becomes self explanatory.
Ko3 actuator swaps are a pita, think yourself lucky! :)
Top bloke, Cheer's Benjamin, that's the answer I was looking for :). I've got an old picture of another k04 I used have and can see the 2x10mm bolt you mean, just wasn't sure they were very accessible in situ.
I found it a little pain tbh. Take the strut brace off, TIP etc for better clearance.
cheers dude, them big tips do get in the way of pretty much everything on that side !
3K
HTC
656
