EM TuningSky Insurance
    Mar 2009
    14
    Timing belt out of driven pulley...problems??
    Hello
    I changed myself my s3 amk timing belt kit with a complete Continental CT909K3.
    after 5-600 km I opened the carter and I found the pulley 1-2mm out of the cams pulley:
    Can be normal? Can I do something? have I to worry about??
    Feb 2006
    Lincolnshire
    692
    I'd check that roller pulley beneath the crank is still firmly bolted in and not trying to drag the belt off, but otherwise it looks good to me.
    Audi S3 - 2002MY - Denim Blue
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,027
    Fairly normal tbh... varies a little where they settle but seen loads like this
    Interestingly you can see from the 'wear' pattern on the belt the its 'shinier' on the outside edge which would cause the belt to 'climb' over that side of the pulley
    <tuffty/>
    Mar 2009
    14
    I didn't removed the roller crank pulley (the smaller for timing belt), I removed only the external pulley ro remove the timing belt carter.
    The shinier edge is again present, however now I will check also the idler pulley bolt and, after that, I hope that all my fears will go far! :D
    Mar 2009
    14
    Thank you for your replies!
  1. Timing belt tensioner/ idler pulley
    By Lemon S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th June 2012, 21:02
  2. TIMING BELT problems on A6 TDI SE Avant 2.5 00
    By currus audi in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 21st March 2011, 18:31
  3. Timing Belt Problems?
    By gkat29 in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd November 2006, 17:04
  4. Timing Belt Question from a newcomer
    By RichbagggA4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd October 2003, 17:24
  5. 2.8 Timing Belt or timing Chain ????
    Last Post: 20th October 2003, 07:10
