Chris NottEM Tuning
Results 1 to 9 of 9
    Jan 2005
    Norfolk
    304
    anyone retro-fitted air-con?
    was thinking about doing it but it appears to be a MAJOR job! has anyone done it and if so how hard was it/what was the total cost?
    Jun 2003
    World of my own
    9,813
    Re: anyone retro-fitted air-con?
    I wouldn't even consider it, that is probably the biggest retrofit job possible!
    Easier to swap cars I'm afraid.
    Khufu's Avatar
    West coast of Scotland
    5,693
    it is a major job. I have fitted the control panel and associated parts (centre console, housing etc) inside the car including all the wiring. I still have to fit the aircon side of it! I do have the rest of the parts apart from a pipe still to get, once I get that it will be ready to be checked and gassed (in time for summer!). Cost is hard to say, i got most parts off of ebay and breakers. Must be about the 500 mark by now. Probably better if you got it off one car all at the same time - I got the whole airbox including motors and evaporator for 27 of ebay and then spent 30+ on the sunlight penetration sensor!
    I did it as much for the challenge - nobody else had done it and most said it would be too expensive too, but its the same price as a remap. When it gets a bit warmer I will be fitting the pipes,compressor and condensor.
    Jun 2003
    Hythe, Kent
    1,180
    It will be expensive, no two ways about it.
    khufu - sunlight penetration sensor? What, where?
    Kev.
    Khufu's Avatar
    5,693
    its the sensor in the middle of the top of the dashboard between the two vents that blow air onto the windscreen. I'm lucky as I have all the wiring diagrams and somebody to gas the system for me.
    Jan 2005
    Norfolk
    304
    what does the sunlight penetration sensor do?
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,846
    [ QUOTE ]
    [/ QUOTE ]
    Tells the CC wether it's daytime or night time, and adjusts the temps to suit.
    Khufu's Avatar
    5,693
    *note* wire it in BEFORE putting the dash back together [img]/ubbthreads/images/graemlins/smile.gif[/img]
    Jun 2003
    World of my own
    9,813
    I wondered what that nipple thing was between the airvents, thanks khufu!
