JMB RetrofitsSky Insurance
Results 1 to 16 of 16
    valyboi's Avatar
    Oct 2012
    Mountain Ash, RCT, South Wales, UK
    119
    Add valyboi on Google+ Visit valyboi's Instagram Channel
    how does atmospheric dump Valve on my 1.8t work fine???
    Hello just bought a new car mk4 golf 1.8t look at it someone have fitted a dv to it already it's called turbosmart kampact bov dump valve I believe it's a atmospheric valve people say they don't suppose to work tidy but this seams fine and don't show no codes ect
    It's on ebay iv found a few much help would be great
    If a jobs not bodged,it's not done right.
    valyboi's Avatar
    Oct 2012
    119
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    Depends on your definition of 'works fine'...
    My wife drove around for a couple of months with the front brake pads so worn it was metal on metal... other than a little bit of noise according to her the brakes 'worked fine'...
    Facts are... atmos valves cause running issues on 20v's turbo engines... some manifest more obviously than others and AGU/cable throttle ECU's are more tolerant fault code etc wise than the more modern ME7 based ECU's...
    The ECU uses the MAF to measure air coming into the engine so it can calculate the injector on time for the correct AFR... atmos valves vent this metered air but the ECU has already worked out the injector ontime for when you next put your foot down... only at this point there is actually less air in the system than it thought it had and the AFR goes rich... this could just cause a hiccup for the engine or cause a misfire from the mixture being too rich... really does depend on whats happening at the time...
    Either way the engines with factory ECU's just run better and cause less issues on recirculating valves...
    <tuffty/>
    valyboi's Avatar
    Oct 2012
    119
    Okay not as that had with the brakes lol
    My mate's got a 1.8t standard car with a forged 007 dv
    I have standard with a turbosmart atmospheric valve
    Both cars feel the same delivering power should I just get rid of this one and get a recurculated one
    valyboi's Avatar
    Oct 2012
    119
    Also my engine code is aum
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    Personally unless you want expensive bling then get a brand new OE valve... it just works... if you must spend money on one then get a new 007 or 008 from Forge...
    <tuffty/>
    valyboi's Avatar
    Oct 2012
    119
    Yeah I think il just buy a proper recir forge 007 8 what's the difference between the two sorry I'm all new to this
    One thing can this atmospheric one do anything bad to my car just to leave it there untill I buy a proper one
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    It won't do damage as such... it just gives running issues... you will be ok but get it done sooner rather than later...
    <tuffty/>
    JUS3IN's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    693
    my standard valve makes a great noise on my mapped s3 imo...
    1999 apy s3, n249 delete, sai and n112 delete. bbs lm reps, s2000 filter, relentless v3 manifold, relentless downpipe and sports cat, scorpion cat back system, badger 5 v3 tip, bam rocker cover, push in coilpacks, toyosports fmic, amd remapped to 280.3 bhp and 263.9 lb/ft.
    valyboi's Avatar
    Oct 2012
    119
    Thanks for the replys guys il have a loot asap now for a recirculatio. Valve
    Aug 2011
    Plymouth
    744
    Add Lavis89 on Facebook
    If you want a bit more noise then get it remapped, mine makes a awesome noise after the map, probably louder than the vent to atmosphere valve that came on the car when I got it
    2001 1.8T Quattro Sport 89k covered ARY engine.
    Remapped at Badger 5, 213bhp - 235lb/ft torque.
    HS2K cone, FMDV008, Silicon TIP, 18" RS4 (reps), AP coilovers, Catch can, n249 bypass, Toyosport 3" Downpipe/Decat, S3 Front brakes, Polyflexed Dogbone, S3dave adjustable tie bars
    Soon to be done: SAI delete, Install the toyosport FMIC i have kicking about in my living room
    valyboi's Avatar
    Oct 2012
    119
    Thank you lavis I was Thinking getting it done soon. Enough
    Aug 2011
    Plymouth
    744
    you wont regret it, i got mine done at badger5 (not too far from you i think), the car is completely different now, so much fun to drive, and im only at stage 1 mods
    valyboi's Avatar
    Oct 2012
    119
    Thanks where to ruffly is badger5
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    Quote Originally Posted by valyboi View Post
    https://www.facebook.com/Badger5Ltd
    Just off J13, M5
    <tuffty/>
    valyboi's Avatar
    Oct 2012
    119
    il have a look
  1. Forge Atmospheric Dump Valve Spacer 2.0T (FMDV14T)
    By mikeyw in forum For Sale/Wanted - Audi Parts
    Last Post: 11th November 2011, 16:39
  2. Who has an atmospheric dump valve?
    By Beerzo in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th August 2006, 10:57
  3. Atmospheric Dump Valves
    Last Post: 6th June 2006, 11:58
  4. Dump valves
    By waynehiscock in forum General Technical / How To
    Last Post: 28th March 2003, 18:15
  5. Diverter Values/ Dump Valves
    By Banwell in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th January 2003, 23:50
