Lambda Wiring Diagram ?
A3 T
Lord Of The Rings
Does anyone have a wiring diagram on the lambda sensors ?
I want to check all the wiring and need to know if the wires that go to the sensors go straight to the ecu or if they go to the fuse box first.
They both utilise the same feed. F43 10AMP. Also using this feed is MAF/EVAP valve/SAI solenoid/SAI relay.
4K
6
