Results 1 to 15 of 15
Like Tree1Likes
  • 1 Post By MattW86
Thread: ill Running '01 S3...advice needed
    MattW86's Avatar
    May 2009
    Norn Iron
    74
    Hi guys,
    Long time since posting on the forum, typical that a fault has brought me back.
    My car decided yesterday afternoon to start running really rough.. like it was misfiring. I ran a quick scan with a code reader I have (not vag-com) which showed no faults and the EML light has not popped up, neither has the low oil / oil pressure warning.
    I took a look at the plugs today and found that in first cyclinder (far left) there was oil covering the electrode but the others were fine. Gave the contacts on the coilpack a clean and replaced the plug with a spare. Started her up but no improvement. There is also a strong smell from the exhaust and when idling the engine makes a audible knock.
    I am clueless as to what is wrong, any ideas guys??
    Matt
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    is your car mapped?
    Did it do this while giving it some?
    Smell of fuel suggests that injectors are working, have you checked for a spark on that cylinder by just plugging coil pack into loom, and pushing plug into the end while laying it on top of the rocker cover for an earth?
    MattW86's Avatar
    May 2009
    Norn Iron
    74
    I haven't remapped the engine in my ownership and no evidence to suggest it has been.
    It decided to do this whilst pulling into a junction at 30mph I gave it a bit of a blip to get up to the increased speed limit then it felt like it was hesitating from low revs. Luckily only a couple of mins from home at the time. Weird thing being that about 15mins earlier it was pounding down the motorway with no problem.
    To explain the exhaust smell abit more, it was eggy in odour. I will give that spark thingy a try when it stops raining here.
    cheers
    Matt
    vrbob's Avatar
    Jun 2007
    Southampton
    2,362
    coil pack died maybe?
    easy way to check is unplug each one while car is running individually and see if it get worse if it does not then that coil pack is fubar`d
    Mods : Badger 5 Stg 2 Custom Map, FMIC, 3" DP & 200 Cell Cat, 007P, Jetex Filter & 80mm TIP & Heatshield, Complete LED Kit, Gen VW Aero Wipers, Full Powerflex Kit, R32 RARB, AP Shocks & Springs, 15mm Front & 20mm Rear Spacers, BB Uprated Actuator,
    Apr 2004
    12,520
    Quote Originally Posted by vrbob View Post
    Ahh could be, i read it as he'd tried the coil pack, not just a plug, doh, serves me right for skimming
    JUS3IN's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    693
    reminds me of when my coilpack went so +1 /\
    can also just pull the injectors plugs one by one which is a little easier. especially if you have bolt down coilpacks and n249 in place. good luck.
    1999 apy s3, n249 delete, sai and n112 delete. bbs lm reps, s2000 filter, relentless v3 manifold, relentless downpipe and sports cat, scorpion cat back system, badger 5 v3 tip, bam rocker cover, push in coilpacks, toyosports fmic, amd remapped to 280.3 bhp and 263.9 lb/ft.
    vrbob's Avatar
    Jun 2007
    Southampton
    2,362
    If it sounds like a tractor on tickover then its usually firing on 3 cylinders.
    Common issue and probably worth upgrading to TFSI coilpacks if one has gone as I think a set of them are cheaper than the normal 1.8t jobbies and you can get adapters from TPS for a couple of quid each as I saw that in Tuffty`s thread a while back
    MattW86's Avatar
    May 2009
    Norn Iron
    74
    Swapped the coils this morning and the engine seems to run no problem however there is a heavy shuddering. It seems to come from the exhaust. Would the fact that exhaust fumes are only coming from 1 tailpipe and the strong eggy smell be cat related?
    Matt
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,634
    Sounds like a Subaru? Lol coilpack. If it's preface lift the EML light doesn't come on, strange that yours hadn't since it's 01.
    MattW86's Avatar
    May 2009
    Norn Iron
    74
    Got a brand new coilpack this morning and popped it in.. it hasnt improved the running of the car. I took a short vid to better describe it.
    Cheers again guys
    Matt
    vrbob's Avatar
    Jun 2007
    Southampton
    2,362
    Quote Originally Posted by MattW86 View Post
    Cheers again guys
    Matt
    Still sounds like the coil packs to me personally.
    have you tried the new coil pack in each cylinder?
    Jan 2012
    Kilmarnock, Scotland
    343
    Stupid question but did you remove the oil from the plug hole?
    vrbob's Avatar
    Jun 2007
    Southampton
    2,362
    also have you checked the coil pack loom as they are know to crumble over time which would give the same symptoms.
    MattW86's Avatar
    May 2009
    Norn Iron
    74
    Gonna give it a fresh go with chopping and changing the coils around. Havent checked the loom.. stuck in work till late.
    I cleaned the oil up and made sure to check the other cylinders just incase. Looks like im in for a cold long night with my engine.
    Matt
    MattW86's Avatar
    May 2009
    Norn Iron
    74
    First thing i have to say is a BIG thanks to ASN members, spent a good bit of time at it this evening. Have now found the dead coil and i am back in the land of boost.
    Car is running perfectly. Thanks again lads
    Matt
    superkarl likes this.
  1. Running 9x18inch wheels on S3 - advice needed on spacers
    By Simplicity in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd April 2013, 10:55
  2. Advice needed on running my A3 on Bio Diesel
    By Cloth ears in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th March 2011, 21:11
  3. A4 (B6) 2.5 TDi - engine running badly - advice needed
    By uber-tub in forum General Technical / How To
    Last Post: 11th October 2010, 10:52
  4. 2.5 Tdi engine running badly - advice needed
    By uber-tub in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th July 2010, 19:50
  5. Please HELP!!! Advice NEEDED!!!
    By AVerma in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th July 2003, 16:34
