Results 1 to 8 of 8
    Jan 2014
    brake light switch and brake pressure sensor fault codes
    hi all,
    my friend has a 2002 audi a3 1.8 5v turbo with automatic transmission. His esp light came on the other day so he brought it over for me to have a look at yesterday. After hooking it up with my vag com cable i found two fault codes, 1 was brake light switch and the other was brake pressure sensor. After clearing the codes they came back so the fault is still there. When i found the brake light switch code i checked to see if his brake lights were coming on and they werent!
    I will be testing the brake light switch this morning and replacing if faulty. Could the faulty brake light switch throw the brake pressure sensor code as well? or are we looking at replacing the abs pump on his car?
    Any hints, tips would be great as i havent got much knowledge of audi's tbh
    Sep 2012
    West midlands
    368
    Quote Originally Posted by welly_59 View Post
    hi all,
    bleed brakes using vcds and new fluid!cured mine!
    Audi s3 8l 2003 silver,brembo brakes,custom front mount intercooler,forged rods,acl race bearings,3inch tip,forge 007p green spring 1 shim,5mm hubcentric spacers,pipewerx 3inch down pipe/200cell race cat,2.75 miltek back non resonated,new piston rings,n249delete,pcv venting too atmosphere,neuspeed quick shifter,uprated clutch/pressure plate...large port agu head,inline fuel pump
    work left/relentless v3 manifold/wmi/blue haldex/antilag/launch controll/custom map!!!!!
    Jan 2014
    cheers for that, can i bleed using vcds-lite? i am using a generic 409.1 cable so not sure if it will work with full version of vcds?!? the brake lights should still come on though surely, as its just a switch that is thrown when the pedal is depressed?
    Sep 2012
    West midlands
    368
    no full version needed
    Sep 2012
    West midlands
    368
    Brake light switch on pedal needs changing easy job!
    Jan 2014
    I've disconnected the brake light switch and the brake lights are still not working, should the lights come on with no switch attached?
    Does anyone know the pin out of the switch or connecting plug? I'll bridge pins to test as all the motor factors are closed today
    Jan 2014
    Anyone know the pinout? I'm sitting in the car with pieces of trim all around!
    Jan 2014
    ok i found the pinouts, pins 1 and 4 need to have continuity for the brake lights to come on. i tested the switch and got no contact between 1 and 4, after messing about with it i got continuous contact between pins 1 and 4 lol so a new switch is going to be picked up tomorrow.
    lets hope this sorts out the brake pressure sensor fault as well
  1. Daylight running light out and brake/suspension fault!!
    By Brownie78 in forum New A3/S3 (8V Chassis)
    Last Post: 7th August 2013, 21:46
  2. Replies: 3
    Last Post: 18th October 2011, 13:06
  3. Replies: 0
    Last Post: 6th June 2011, 17:11
  4. ABS and ESP lights - Brake pressure sensor fault - Help!
    By wilkoa6 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 25th March 2010, 15:45
