Badger5AH Fabrications
    Aug 2013
    2001 AMK s3 temp problem
    Hi all,
    currently have problems with temperature
    car warms up to midway then drops right off down to starting temperature.
    The car never over heats.
    I have bought a new thermostat ( could do with someone posting a thread for fitting it)
    anyone know of anything else that could be causing the problem?
    regards
    Tom
    May 2013
    Birmingham
    211
    It could be Thermostat or CTS I didn't have too much trouble with the stat but you want some probably about 1ft extension and a wobble attachment for the socket as it is awkward to get to. A bit of info on here: Thermostat change.
    The CTS is easy only takes 5 minutes take the main engine cover off then look down the right of the engine under some pipes you can see a plug into the engine. Remove the plug and there is a clip at the base holding the sensor in make sure you get the old I ring out with it then replace.
    Sep 2004
    47
    I had the exact same problem a few weeks ago. I bought a bew thermostat and had that changed whilst car was I garage for other work and its worked perfectly since.
    epox's Avatar
    Oct 2012
    Glasgow
    561
    Do a search mate, I posted a whole load of pictures and explanation of what needs done, its on here some where
    Mark
    S3 2003........REVO..........Stage 1...........218G/S.......÷..........°8..........=..........272bhp ......368Nm.....271 ft lbs
    May 2013
    Channel Islands, Jersey
    82
    +1 to all these guys, i had the exact same problem on my AMK S3. It too ages to get upto 90. It then would drop off too 70/80 if heaters put on or if in traffic etc.
    Change the thermostat! I just did mine yesterday, and now back to normal
    Audi S3 AMK, Badger 5 Tip with Cone and Heat Shield, Forge 007P (green spring), de-cat pipe
    Oct 2011
    greater mcr
    114
    me too, changed the stat and all fine now
    2002 bam s3, 3" custom turbo back/decat, unicorn MD custom map with pops n bangs ;-), b5 tip, s2k filter, forge 008, uprated intercooler, more to come :-)
  1. Audi S3 cylinder head problems!! 2001 AMK
    By stoneys3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd February 2012, 18:06
  2. Coolant and temp problem
    By low610 in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th February 2010, 20:12
  3. tt temp problem!
    By H-M3 in forum TT/TT-S/TT-RS Forum
    Last Post: 18th February 2008, 10:21
  4. 2000/2001 A3 TDI (ENGINE PROBLEM)!!!
    By mr964porsche in forum Diesel forum
    Last Post: 26th June 2006, 23:32
  5. Water Temp Problem
    By m_o_w_g_l_i in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th December 2005, 23:16
