AH FabricationsVolks Autos
Results 1 to 14 of 14
    justarn's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    587
    Help with squeeling noise from the rear? with videos.
    Hello all, another problem... uuurgh... went out earlier and thought I could here a minor wheel bearing squeel metal on metal type noise. Hardly noticable to the point where I wondered if it was in my head. I was nearly home then on a big wide wet t junction thats covered in crud I floored her and got some nice oversteer out of the corner, lovely!-) anyways after that maneuver the noise got very loud. Its a constant squeel that dissappears at speed and is most obvious decelerating below thirty? My first thoughts are wheel bearing our loads of grit in between the disc and pads?
    Any help, similar experiences with rear wheel bearings on 4wds?
    1999 apy s3, black & blue interior,dare bbs lm's, s2000 filter, relentless v3 manifold, relentless downpipe and sports cat, scorpion cat back system, stock dump valve, badger 5 v3 tip, bam rocker cover and push in coilpacks, toyosports fmic, amd stage 2+ remap 280.3bhp 263.9 lb/ft.
    tardinabox's Avatar
    Sep 2013
    Carlisle
    44
    Mines doing this, drives me crazy. I think its the brake pads rubbing on the disk.
    justarn's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    587
    im pretty sure its our wheel bearings mate, sometimes they groan sometimes they run dry and squeel... theres a kit inc the hub assembly on ebay for 70 quid so its not too bad.. not sure how hard this would be too fit? need a press?
    AUDI S3 1.8 QUATTRO REAR WHEEL BEARING HUB ASSEMBLY APY AMK AUL 210 1999 - | eBay
    justarn's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    587
    this noise which was confirmed wheel bearing is the same? im just posting up a video of me spinning the wheel stationary.
    justarn's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    587
    my car...
    justarn's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    587
    whoops double post...
    justarn's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    587
    No one huh?
    tardinabox's Avatar
    Sep 2013
    Carlisle
    44
    Hmm sounds like my old focus when the front bearing went. Mine sounds more high pitched but stops when you wet the disks
    justarn's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    587
    mine sounds high pitched when driving,,, think i'll have the caliper off and check for ****e and brake pad snappage then spin her and see if the noise is there with no caliper... its just finding the motivation at the weekend after a hard weeks work uuurgh. kwistof told me he had a snapped pad that created a similar noise, maybe i never got power oversteer and it was the pad broken and jamming??
    tardinabox's Avatar
    Sep 2013
    Carlisle
    44
    maybe disked is warped slightly? need to get mine off aswell its just too cold lol
    justarn's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    587
    same cold and dark lol or cold and light at the weekend...
    cant believe me and tardinabox aint had more help with this, so many knowledgeable people and no-one has an opinion or solution?
    justarn's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    587
    well its sorted lol, it was a stone jammed in between the disc and the back plate of the disk, cheapest fix ive had for a long time!
    ChrisP1303's Avatar
    Jan 2013
    Towcester
    191
    I had this about 3 weeks into owning my A3 thought ah crap. Pinged the disk back plate out dropped a massive stone. Problem solved on mine too!
    tardinabox's Avatar
    Sep 2013
    Carlisle
    44
    Hopefully mines that simple lol
  1. Strange noise from the rear at low speed when turning
    By 86fran in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th January 2013, 20:28
  2. sort of droning noise from the rear end.
    By 205man in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th January 2012, 22:08
  3. strange noise coming from the rear of the car (S3)
    By mattyboy199 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th September 2010, 14:09
  4. Clunking noise coming from the rear end
    By jumpers in forum Handling
    Last Post: 15th September 2008, 22:48
  5. noise from the rear of my car.
    By millsyd in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd September 2006, 21:37
