AH FabricationsVolks Autos
Results 1 to 8 of 8
    Looking for parts :P
    Dec 2013
    Bury St. Edmunds
    68
    S3 using excessive oil.
    Hi guys I was wondering if anyone could shed some light on my situation. I commute 150 miles on Friday to get home from work, and then the same when I go back again on Sunday. I bought an S3 a couple of months ago and it has been fine but all of a sudden the low oil light came on, I topped it up with 1/2 litre and within 1 150 mile journey the light came back on again, so again I've put 1/2 a litre in, and now after the 3rd trip the light has come on for a third time. There are no oil leaks, no loss of power, and it isn't smoking at all. What can be at fault?
    mark_S3's Avatar
    Yorkshire & Humber Events Rep
    Sep 2012
    Wakefield
    600
    Audi suggest around a litre of oil is burnt every 1000miles.
    Seems as your situation is normal to me.
    ***2000 Audi S3 8L APY***
    * Milltek CATback * Milltek 200 Supercell Sports CAT * SuperChips SPS Stage 1 Remap * Forge 008p *
    * 18" Audi TT 240 Sports Alloys in Gunmetal Grey * Pagid Discs with BD Predator Pads *
    * Badger5 v2.2 TIP, JR Filter with Heatshield * N249 Delete * N112 Bypass *
    * PowerFlex ARB Bushes * TFSI Coilpacks * Saikuo Michi S3-OCC *
    * PowerFlex Rear Engine Mount Bushes *
    [IMG][/IMG]
    bigray's Avatar
    Oct 2013
    leeds
    148
    Quote Originally Posted by mark_S3 View Post
    i think he means its using 1/2 a litre of oil for every 150 miles ?
    Crazypete00's Avatar
    Oct 2007
    266
    Take the charge pipe to inter cooler pipe off and see if there is much oil in there. Or in the throttle body. Also check the oil drain plug, as the s3 has a aluminium sump if some one hasn't put it in correctly it will knacker the thread
    Nov 2012
    Daft question, but why half a litre?
    Usually, the difference between the min and max mark on the dipstick is 1 litre, but you don't usually get a warning light on the min mark, the warning light comes on when it's a bit lower than that.
    So if that is the case, why half a litre? What's the dipstick saying?
    The other thing to do is to get a piece of white cloth and give the side of the car (along the bottom) a wipe with one half of it and then give the rear of the car a wipe with the other half of the same side of the cloth. Compare the 2 half's and if the back half is noticeably blacker, then it could be oil residue being burnt through the exhaust.
    Aug 2013
    manchester
    25
    Quote Originally Posted by Crazypete00 View Post
    yer al second that i was the reason the traffic wombles got to clean up all my oil after i swung a lil too hard on the old spanner . sorry if u use the m60 that was me that made u late .
    Dec 2013
    Bury St. Edmunds
    68
    Yes sorry for my bad explanation it's using about 1/2 a litre every 150 miles. Because I've been half way through my drive when the light comes on I've just topped it up with half a litre. But I will do as you say Pete and report back. Thank you
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    The "idiot" light coming on means the oil is REALLY low, well below the dipstick. Don't let it get that low or you'll stuff your engine eventually.
    Top it up to full on the dipstick (not any fuller). Then you can monitor the usage/drop after each drive.
    If I were you I'd be checking the level BEFORE every journey too.
    My oil consumption depends on how hard I drive the car.
    Liam
    S3 AMK 2002. Only 203 BHP left in my poor little engine, currently searching for the 7 missing horses.
    Mods: Powerflex bushes at the front and rear, 710P DV, ambient light module, Badger5 V3 TIP, S2000 Filter.
  1. Does your 2.0TDI use much oil?
    By s-line stu in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 18th January 2010, 22:07
  2. Excessive Oil Consumption.........
    By RobinA3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th January 2009, 18:22
  3. Excessive Oil Filter Pressure??
    By Sm[]key in forum Diesel forum
    Last Post: 30th March 2007, 21:14
  4. ** Help, Think Ive Used Wrong Oil **
    By JustSports in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th February 2007, 18:53
  5. Excess Oil Usage ??
    By PaulBelsham in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th January 2003, 22:38
