Volks AutosBadger5
Results 1 to 8 of 8
    JoeeS3's Avatar
    Apr 2013
    Cardiff
    355
    Follow JoeeS3 On Twitter Visit JoeeS3's Instagram Channel
    what's needed for a stage 3 s3 8l
    Apart from a bigger turbo what other mods would I need on top of my current ones to take my car to stage three going to get all the parts ready for summer then it's all going to go in then
    Cheers guys here are my current mods
    *New integrated engineering strengthened H beam con rods and ARP rods
    *a&h fabrications inter cooler *all air pipes have been replaced with sfs up rated silicon pipes
    *forge recirc dump valve
    *3" s/s pipeworx down pipe and decat pipr
    * from cat back s/s power flow system
    *40mm eibach springs
    *uprated anti roll bar with poly bushes inc T bar engine mount
    *itg 350bhp rated air filter
    i'm not a genius...i'm a learner
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,271
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    Injectors and a decent clutch to be able to deal with all the extra power
    2000 S3 APY
    18" BBS RSII with Michelin PS3s, 20mm H&R adapters, Relentless 3" DP and Sports cat, B5 V1 induction kit, cone filter+heat shield, Forge 007P, Awesome GTI SMF, AP coilovers, Facelift rear lights, Full Powerflex poly bush kit, R32 Rear ARB, SAI delete, N249 by-pass, Upgraded Engine mounts with Polytek, Stage 1 CC at Badger 5.
    JoeeS3's Avatar
    Apr 2013
    Cardiff
    355
    well as my flywheel is on the way out i firgured i would upgrade it now in preperation
    JoeeS3's Avatar
    Apr 2013
    Cardiff
    355
    does anyone know if this would be okay for my car AUDI A3 1.8T T S3 QUATTRO FLYWHEEL, CARBON KEVLAR CLUTCH, CSC, BOLTS | eBay
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,556
    What turbo are you planning on using to go 'stage 3'?... if sticking to a K04 variant then you haven't got a Badger5 TIP in your list or high flow exhaust manifold...
    If looking at a larger framed turbo such as a garrett then arguably you need to also consider valve train and possibly a large port head...
    Be easier if you state a power goal... stuff like rods etc are a given in most cases these days but of course you also need to consider wear and tear on the engine itself... if looked after the 20v will go on for 200k... but... starting to see some 100k+ engines that are a bit of a lottery as to condition... I would consider getting a compression test/leak down test done on the engine as a minimum... if replacing rods then also consider at least changing the rings too...
    While the heads off its worth getting a small refurb done on it so guides checked and replaced if required (typically exhaust guides), new stem seals and relap the valves in
    <tuffty/>
    Artsa's Avatar
    Sep 2013
    Chepstow
    156
    If replacing rods then also consider at least changing the rings too...
    <tuffty/>[/QUOTE]
    Hey Tuffy, How much roughly do you think I would be expected to pay (Roughly) to get this done on my standard S3 if I supplied the parts?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,556
    Quote Originally Posted by Artsa View Post
    Hey Tuffty, How much roughly do you think I would be expected to pay (Roughly) to get this done on my standard S3 if I supplied the parts?
    For what exactly? rods fitting and head refurb? Bill charges around 1300 quid for just the rod change inc parts IIRC... does not include rings and head refurb though better off giving the man a call for a quote...
    <tuffty/>
    Artsa's Avatar
    Sep 2013
    Chepstow
    156
    All of the above really, I'm looking for more power but I wanna do it right. I don't know where to begin... I don't want silly power but I want reliability.
  1. What's needed for stage 3 on s3 8p
    By katenick in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th July 2013, 17:48
  2. Whats needed for Shark Stage 3
    By ilim in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th December 2012, 23:26
  3. What is needed for "stage two"
    By benppl in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th January 2012, 00:24
  4. What's needed for stage 2 revo
    By quattro rob in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th December 2009, 22:45
  5. What tools needed for...
    By j4g3d in forum General Technical / How To
    Last Post: 26th January 2007, 18:38
