Badger5Sky Insurance
    Racehunter's Avatar
    Jan 2014
    Non Running S3 - Fuel Pump Not Running?
    A friends S3 (1999) suddenly stopped, as it would have it, right outside his office!. Anyway, it is now sitting in my workshop and it appears the fuel pump is not running. Now, I do not post blindly (knowingly that is) and have searched the forums across the WWW for some information relating to wiring diagrams etc, as an aid to the problem solving. However, I have not actually found that much useful (to me) information.
    I have exposed the fuel pump, and given it a little 'hard stick' persuasion to no avail. I have checked fuse 28 and all is good. I have also put a meter to the pump harness plug and without the benefit of any wiring info, come to the conclusion that the 2 outer wires (of the 4) are for the pump while the inner are sender related. I also assume that the outer brown is earth and the outer blue/red is 12v supply. Now this is what I have seen on the meter:
    Ignition on - .02V
    Cranking - 9.1V
    How does this system work? does it wait for pressure to be sensed in the fuel rail before switching on an 'ignition live' supply through the relay or what. Now I appreciate that this might be the correct figures (although 9V seems somewhat low to me) and the problem is a failed pump, but without further information, I am loathed to play the 'replace if not sure' fitters approach to repair.
    Any suggestions would be gratefully recieved especially on the voltage readings at the pump. Also circuit information for the relay to enable me to test that item and is there any such thing as an 'auto off' fuel switch in case of accident and if so, have these been known to fail.
    Anyway, many thanks for reading and hopefully replying.
    Steve
    Racehunter's Avatar
    Jan 2014
    Doesn't anyone have a wiring schematic for the fuel system? Or a link to one? Really need to understand why there is such a voltage drop at the pump connector.
    Steve
  1. Replies: 5
    Last Post: 22nd November 2013, 20:38
  2. 2.0tdi fuel pump not making sucking noise
    By Ade6 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th June 2013, 13:17
  3. Fuel pump upgrade after big turbo conversion, what are you running??
    By S3_nick in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th July 2012, 08:40
  4. air con / after run water pump not working ugh!
    By colicabcadam in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th July 2011, 17:12
  5. Over run water pump not working
    By Speedy Steve in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th February 2010, 16:35
