Monster MotorsportEM Tuning
Results 1 to 25 of 25
    Nov 2011
    Leeds, UK
    287
    No reading when trying to check parasitic drain with multimeter. Help!
    Evening all.
    I thought I knew what I was doing with the multimeter, but the damn thing is saying 0 to everything when I try to test for battery drain.
    Followed this guide to the letter:
    How to Find a Parasitic Battery Drain: 9 Steps (with Pictures)
    I believe that I need the multimeter dial set to the big A on the right hand side, is that correct?
    If that's the case, then why on earth does it say 00.0 or 0.00 etc. when it DOES drain the battery if left overnight??
    Mar 2013
    Devon
    605
    Just checking the obvious, but you had the test leads in the bottom 2 sockets and the meter in series with the battery negative?
    Nov 2011
    Leeds, UK
    287
    Yep. Checked it can read the battery voltage etc. OK too so that I can rule out anything being dead.
    It's bizarre.
    Tried the 10A setting bottom right too. I then put the battery lead back on, read the voltage and watched it flicker, 12.05, 12.04, 12.03 so there must be SOMETHING going on, but unfortunately it looks like I a never ever going to get to the bottom of it.
    I got a Vag Com scan done the other day, and there were three entries, N75 short to ground - intermittent, Lock/Unlock switch; interior short to ground and Tailgate Open Switch short to ground. These are basically all I have to go on now I think.
    Most of these codes are from before I had the car, so the next time I get it read may shed a bit more light.
    Mar 2013
    Devon
    605
    Meter should be on 10A or 200m, any less than that and you may damage it.
    Odd it's not reading at all, maybe try and borrow another meter?
    Nov 2011
    Leeds, UK
    287
    It's brand new to be honest and like I said, reads the voltage fine....
    Lewis583's Avatar
    Mar 2010
    870
    Right, black probe in the "COM" port. Red probe in the top "10ADC" port.
    Turn the dial so that it is in the 10A position.
    Disconnect the battery earth.
    Put red probe on the earth cable. Black probe on negative terminal of the negative battery terminal.
    Check for a reading.
    Is that exactly the method you followed?
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    Nov 2011
    Leeds, UK
    287
    I put the red on the battery Pole and black on the negative lead, as per the guide I linked to, but otherwise yes.
    RIP S3dave
    May 2004
    nr Glos
    7,173
    you are using 10A switch setting and plugged in accordingly yes? and using it "in series" with either the +ve or -ve battery lead yea?
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    Feb 2006
    Lincolnshire
    719
    How do you know your battery is good?
    It would be quite a drain to drop the voltage as quickly as you suggest.
    Get the battery checked or swapped out is what I'd do.
    Audi S3 - 2002MY - Denim Blue - Gone
    VW Polo GTI - 2011MY - Candy White - Here
    Oct 2013
    in the middle
    110
    hi
    funny stuff electricity, just won't stay where you put it
    assuming the meter was connected in series, if you used the bottom two terminals, and any of the lower amp setting on the dial, ie the next segment clockwise from V~, you probaly blew the inernal fuse, as this part of the meter can only hande 200ma, whcih is way less than the initial surge when connecting the battery.
    to measure on the higher range, you need to use the top and bottom terminal, com and 10ADC and set the dial to 10A
    If you did connect using the lower range there is a chance that the fuse did not protect the meter, it is possible for it to measure volts but the amps section to be dead
    good luck
    Alex C's Avatar
    Lizard, Cornwall
    2,602
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    Nov 2011
    Leeds, UK
    287
    Yes to Badger5. Tooks, the battery will still have 12v if left disconnected for a week, so no issues there.
    Best check that fuse then. What sort of fuse is inside one of these meters?
    Oct 2013
    in the middle
    110
    from the manual
    To continue protection against fire, replace fuse only with the specified
    voltage and current ratings: F 250mA/250V (Fast Blown) Ø 5 x 20
    http://www.histest.com/blog/files/20...ers-Manual.pdf
    no fuse on the 10A circuit, if thats not reading correctly the meter may be dead
    do you know anyone that can check it?
    m
    epox's Avatar
    Oct 2012
    Glasgow
    587
    Open up the Meter and check the fuse?
    Mark
    S3 2003........REVO..........Stage 1...........218G/S.......÷..........°8..........=..........272bhp ......368Nm.....271 ft lbs
    Feb 2006
    Lincolnshire
    719
    Quote Originally Posted by Bad Sir Culation View Post
    Battery voltage is no guarantee of a batteries health.
    There will always be a drain on the battery when parked up, but not enough to cause a healthy battery problems.
    What are the symptoms that lead you to think something is draining the battery? Is it flat come the morning? Is it lazy to start?
    Have you checked the health of the earth points, particularly the one on the engine block? Are you getting a healthy 14+ Volts from the alternator? I understand the car is newish to you? Is the alternator the right amp rating? All this can gradually wear a battery down/kill it.
    Apologies if you've checked all this, or I'm teaching you to suck eggs, but faulty batteries are common. My wife had a car with all sorts of weird stuff going on, wipers self activating, sometimes dead, sometimes firing up first time, and a new battery cured it.
    Good luck finding it anyway, electrical problems are indeed maddening!
    Nov 2011
    Leeds, UK
    287
    Quote Originally Posted by Tooks View Post
    No it's fine, any help is appreciated. Alternator I thought was fine as testing battery voltage while the engine is running shows 14+v. Am I wide of the mark in thinking that's proof of alternator health? Not sure how I check it is the correct rating?
    Reason I know the battery is draining is because if I leave it connected overnight, it is dead the next morning. Tries to start if you're lucky and quickly dies completely. Multimeter shows something like 5 or 6v at this point usually.
    Nov 2011
    Leeds, UK
    287
    Quote Originally Posted by newbster View Post
    from the manual
    m
    Strange! The meter is literally a month old. I DO have another somewhere that needs a battery in.... if I can find it!
    Oct 2013
    in the middle
    110
    what was the first connection you made? if it was using the lower range you could well have damaged the meter, despite having a fuse, they don't call electronics "fuse protection devices" for nothing , i've blown more meters than people have turbos!
    i'm about an hour south of leeds, just of M1/M42, if you're passing anytme i can have a poke around with the meter
    "No it's fine, any help is appreciated. Alternator I thought was fine as testing battery voltage while the engine is running shows 14+v. Am I wide of the mark in thinking that's proof of alternator health? Not sure how I check it is the correct rating" This shows its charging ok, but not that it may have a reverse drain when you switch off.
    Nov 2011
    Leeds, UK
    287
    I have made some progress this evening. I found my old multimeter which worked a charm.
    The drain was generally sat around 2.5 to 3 amps, with the odd spike here and there when messing about with fuses.
    The end result of tonight was that pulling the fuses, both at the end of the dash and in the battery top fuse box, made no difference to the drain.
    What am I to make of that? I know my hazard switch is faulty and needs replacing, but even if this was to blame, wouldn't one of the fuses also be for the hazards and thus cut the circuit when pulled?
    Oct 2013
    in the middle
    110
    could be the alternator (probable) or starter motor(low probability), both are connected direct to battrey via bolted fusible links, so no fuse in fuse box
    you would need to unbolt the connections, i recall them being on top of the battery
    good luck
    Nov 2011
    Leeds, UK
    287
    Cheers I will see if I can locate them and try it tonight.
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,087
    Dude, I can guarantee you (well almost) its the black cable going to the alternator in your fusebox on the battery thats going to be causing the drain.
    Put the multimeter on there and you should probably see about a 2.5amp drain.
    Mine did the same and it ended up being a diode in the alternator that was causing the issue. Replaced the alternator and all ok now.
    Nov 2011
    Leeds, UK
    287
    How do I actually test it? Can I just disconnect the lead and keep the multimeter in series with the battery?
    Nov 2011
    Leeds, UK
    287
    Result!!
    Well, it's only the bloody alternator. Great! But at least now the mystery is solved. Thanks very much to all that have helped me with this, it's really got me over the line.
    Edit: I did also want to ask another question. If I leave the radio knob popped out in the ON position, the radio comes on when I am testing the circuit in series. I don't need to worry about the radio draining the battery whenever I leave it like that do I? It doesn't stay on or anything when the car is shut off. Just weird it comes on when I am testing.
    Nilz's Avatar
    Apr 2006
    10,087
    As my son says...toldja!! LOL
    I had the same headache trying to work the issue out too.
    Not too sure about the radio issue though.
    Glad you are getting it sorted.
  1. Check your drain holes, people
    By AndyMac in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th June 2012, 20:25
  2. Seats stopped sliding forward (and back) when trying to allow passengers in da back??
    By kevin00 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd November 2011, 17:22
  3. diagnostic check came up with some faults
    By turboaudi in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th February 2007, 14:01
  4. trying to locate a particular relay..... any help out there?????
    By edmanning in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 27th September 2005, 21:35
  5. Check engine light on!!! Need Help Any clues
    By audia4t99 in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th September 2005, 17:55
