Volks AutosJMB Retrofits
Results 1 to 8 of 8
    Mar 2013
    55
    Adjustable tie bars & camber correction bushes
    Has anyone any experience or view on using both adjustable tie bars & camber correction bushes (the likes of which are sold by Superpro)?
    Not necessarily the camber correction bushes on the adjustable tie bars but maybe adjustable tie bars fitted in either the top or lower position with the bushes fitted to the OEM in the other location.
    sssline's Avatar
    Apr 2012
    Essex/London
    135
    There's a group buy on at the moment, don't know if it's still going. Most people put these on to correct camber if car is lowered. Dave has tried and tested ones which are relatively cheap. Check out the group buy thread it's got lots of info.
    Mar 2013
    55
    sssline - thanks for the reply. I'm on the list for a set of Dave's adjustable tie arms. I was just wondering whether there's any point in fitting camber correction bushes to these or the remaining OEM tie bars that would still be fitted?
    sssline's Avatar
    Apr 2012
    Essex/London
    135
    Ah I see what you mean. I haven't got any experience but there is a thread here which may help:
    Defcon Bush Inserts
    Hope that's useful
    Mo
    Mar 2013
    55
    sssline - thanks for the reply mate. However the link you've posted is for the front wishbone bushes.
    I'm interested in the camber correction bushes for the rear tie bars.
    Mar 2013
    55
    Anyone got any experience of using these bushes?
    epox's Avatar
    Oct 2012
    Glasgow
    600
    Don't think there would be any point in the bushes if you are getting a set of adjustable tie arms as these will sort out the camber.
    Mark
    You could change the existing set of inner bushes with a set from Dave..on the OE arms.
    S3 2003........REVO..........Stage 1...........218G/S.......÷..........°8..........=..........272bhp ......368Nm.....271 ft lbs
    Mar 2013
    55
    epox - thanks for the reply. Plan is to get poly bushes in all 4 arms anyhow. After more reading on the subject I think I'll go with what you noted and change all of them for the same standard bushes but of a poly variety.
  1. ADJUSTABLE TIE BARS CHEAP
    By 242spot in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th October 2006, 12:59
  2. adjustable tie bars
    By mk1085 in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th August 2006, 17:35
  3. Adjustable tie-bars
    By Defratos in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th July 2006, 19:46
  4. Advice please on adjustable tie bars / arms
    By rgb8888 in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th May 2006, 19:09
  5. adjustable tie bars
    By cyuen in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd May 2004, 14:14
