Monster MotorsportEM Tuning
Results 1 to 8 of 8
Thread: heated mirrors
    jpda3's Avatar
    Nov 2004
    Teesside
    117
    heated mirrors
    someone will know the answer to this ...........
    what controls them? [img]/ubbthreads/images/graemlins/noidea.gif[/img]
    is it .........
    1 outside temperature
    2 temperature/setting on the climate control
    3 something else
    also does it clear 'condensation'
    the reason i ask is after being parked all day at work yesterday
    the windscreen and rear screen were iced up and the wing mirror had the 'condensation'
    this didnt clear very quickly
    i think it is outside temperature, as when i replace the glass last year there was a.....
    for now call it an electronic part some kind of temp sensitive resistor
    quick test could be to remove the mirror and put a meter across the 2 black wires
    any ideas?
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,846
    Re: heated mirrors
    I'm pretty sure they are operated by the outside temps going below 5 degrees C, they will also come on if you flick the rear demister on, the mirror adjuster knob has to be in the central position aswell.
    At least that's how it id on my 1999 S3.
    Numptie of the highest order
    Jun 2004
    Crowthorne, England
    2,512
    Re: heated mirrors
    To the best of my knowledge and after buying a new one from an Audi spares dept and having a chat with the guy - nothing controls them (on pre-facelift cars anyway) there is a temp sensor on the back that controls how hot they get, but other than that I belive they are on all the time. I think this is correct too as I've seen rain get dried off pretty quick on my car.
    The weather hasn't got above 5 for ages for me but I'll check next time it does! I have never turned on the demister or played with the adjuster to get them to work, but my car does seem to be different to others sometimes which is typical [img]/ubbthreads/images/graemlins/laugh_roll.gif[/img]
    Khufu's Avatar
    West coast of Scotland
    5,693
    Re: heated mirrors
    The pre-facelift mirrors were on all the time and hence burnt out premiturely. Later models had a thermistor that meant they only came on at temps of less than 5 degrees. As far as I'm aware they have never been connected to the demister switch, but I could be wrong.
    jpda3's Avatar
    Nov 2004
    Teesside
    117
    Re: heated mirrors
    i knew some one would know
    should have said it a facelift 2001
    know they use to work over a year ago so i have forgotten..... vague memory of steam....
    if it was automatic or via the CC
    dont remember using the rear demister
    jpda3's Avatar
    Nov 2004
    Teesside
    117
    Re: heated mirrors
    note to self.......
    before removing mirror glass to test
    check the f##king fuse!!!!! [img]/ubbthreads/images/graemlins/bang.gif[/img]
    removed mirror put meter across terminals, circuit was made
    tested across wires no reading
    [img]/ubbthreads/images/graemlins/book.gif[/img] to see if there was a fuse listed
    there it was fuse 1 10A
    25p fuse replaced..... wonder how much the dealer would have charged for that
    just got to wait for another cold spell now
    wasnt going to take glass off again
    silver75's Avatar
    Big Ron
    Sep 2005
    at work
    3,243
    Re: heated mirrors
    sorry to hijack.. my mirror got bashed and now the glass is "loose" from the housing (electric adjuster doesnt work properly) do i need to remove the glass to fix this??
    darko's Avatar
    Dec 2004
    london, uk
    272
    Re: heated mirrors
    just to add to this one - i have just hired a vw touran and the heated mirrors only work with the mirror adjust knob in the middle position. might be the same as A3 / S3 - on the touran the middle position of the knob also had a symbol showing the mirrors being heated.
