Volks AutosSky Insurance
Results 1 to 7 of 7
    Sep 2004
    40
    Oil level Sensor & N75
    Hi all,
    Took my 2000 S3 to a local VAG specialist today as I had an amber oil sensor light come on.
    Turns out the oil level sensor has died so a new one needs to be fitted.
    When the diagnostics were plugged in it also threw up a dodgy N75 and they have suggested again a replacement having checked all the hoses.
    My question is where is the best place to buy these parts?
    I'm not after oem per say but a good quality part none the less.
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    823
    Add Vex182 on Facebook
    I would stick with OEM for both them, you will only have to change them sooner if you buy non genuine. A genuine N75 can be purchased from eBay easily, make sure it's brand new and the correct code.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, N249 bypass, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    9,640
    I got my Oil Level Sensor from Euro Car Parts, was about £47, its a genuine one, but just had the make filed off.
    The N75 was from TPS, cant remember the price, but wasnt that expensive to be honest.
    Vex182's Avatar
    Apr 2012
    Hinckley
    823
    http://bit.ly/1gehgZh
    That's the exact one I used and it seems to be doing the job fine.
    Sep 2004
    40
    Quote Originally Posted by Vex182 View Post
    Thanka guys will give that a look. Ideally want the car to be running spot on so I can have it mapped eventually.
    Sep 2004
    40
    Does anyone happen to know the correct codes for a 2000 S3 APY oil level sensor and N75 valve?
    Apparently there are two very similar for the oil sensor but I can't check as I have no access to get under the car
    Sep 2004
    40
    Is anyone able to help or advise me as to how I can work which specific part numbers I need?
  1. Oil level sensor problem ?
    By luis.filipe in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 22nd April 2011, 22:32
  2. Oil level sensor
    By ianysm in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st January 2010, 22:14
  3. Sump oil level sensor conversion
    By lucksta in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th April 2009, 20:46
  4. Oil Level Sensor on Early S3's?
    By metricspaces in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th February 2009, 16:08
  5. Replies: 1
    Last Post: 17th August 2007, 23:10
