JMB RetrofitsBadger5
Results 1 to 26 of 26
Like Tree3Likes
  • 1 Post By Dan-A3-Quattro
  • 1 Post By GarethEvans
  • 1 Post By antwan64og
Thread: This damn Idle :(
    Pubemammal's Avatar
    May 2013
    Braintree Essex
    440
    Unhappy This damn Idle :(
    Hello guys, I am struggling with this awful idle issue on my 1998 A3 1.8T.. I have tried unplugging the MAF, cleaning the TB, resetting the TB, replacing vacuum hose, checking all other hoses for leaks/splits etc. Still the problem persists.
    The car will hunt for a few seconds then settle down, however if I coast along with the clutch pressed down, the hunting will continue until I come to a standstill!?
    Idle - YouTube">Idle - YouTube" type="application/x-shockwave-flash" width="170" height="140">
    Any help or ideas would be appreciated.
    Progress Thread - http://www.audi-sport.net/vb/a3-s3-f...thread%5D.html
    A3 8L 1.8T AGU BLACK
    Pubemammal's Avatar
    May 2013
    Braintree Essex
    440
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,247
    fault codes ?
    Audi A3 8L 1.8T breaking.
    front bumper, impact bar, slam panel, full engine and loom sold.
    everything else for sale.
    Pubemammal's Avatar
    May 2013
    Braintree Essex
    440
    My little rubbish fault code reader says no fault codes :/
    Feb 2012
    1,125
    Ive got similar issue. Starts lumpy to.if you rev it its rough. Is yours? I was advised to get my injectors cleaned.
    Nov 2013
    108
    A new ignition control module fixed my erratic AGU issue, I went through new plugs, new coils, fuel filter and vacuum lines before I took a punt changing the ICM.
    You can test it with a volt meter there's guides online but I just decided to change mine.
    Idle was that bad I was convinced the flywheel was shot and about to exit the gear box.
    Good luck tracking down the issue
    Pubemammal's Avatar
    May 2013
    Braintree Essex
    440
    Quote Originally Posted by daz-20vt View Post
    Mine is fine through the rev range its only the ideal causing an issue buddy
    Quote Originally Posted by antwan64og View Post
    Ah ha I think you might be on to something here matey... as the issue started around the same time I fitted the s2k filter and had to relocate the ignition control module. Would the relocation of caused that to happen? It is currently fixed to the forward facing side of the bulkhead.
    Nov 2013
    108
    Quote Originally Posted by Pubemammal View Post
    Mine is fine through the rev range its only the ideal causing an issue buddy Ah ha I think you might be on to something here matey... as the issue started around the same time I fitted the s2k filter and had to relocate the ignition control module. Would the relocation of caused that to happen? It is currently fixed to the forward facing side of the bulkhead.
    location should matter too much if it is secure.Theres no clear cut symptoms when the ICM goes, anything from intermittent spark issues to non firing of specific cylinders. Most annoying is that it doesnt throw a fault code so its hard to track dowm.If you know anyone with a 1.8 VAG from the same era swap in theirs and see if that fixes it.It might not be the ICM but its something to look into.
    s3joe's Avatar
    Mar 2012
    Liverpool
    296
    Visit s3joe's Instagram Channel
    If you have cleaned your tb it might want putting back to basic settings using vcds
    Jan 2014
    I had idle issues when I first got my A3. I had the fuel filter replaced and it cleared the problem.
    WorkInProgress's Avatar
    Oct 2012
    Scotland
    237
    Add WorkInProgress on Facebook
    I did away with my ICM and this solved my poor idle issues, pricey option as you need new coils and adapters (£350 ish)
    http://www.psituning.com/product.php...9dbe57a3408b87
    1999 1.8t AGU Sport 150 5dr
    Fitted
    2.5" Decat Downpipe, 2.5" MeerKat Custom Cat-Back, R32 Wishbone Bushes, Black Diamond 12 Groove Discs, Phatnoise, S2000 Filter, HKS SSQV, BBS CH Rims,
    Koni STR.t Kit
    Awaiting Fitting
    ABT Rear Spoiler, Oettinger Grille, Catch Can
    Wanted
    5dr Black Leather Interior (Golf/Bora/A3)
    Plans
    Flocked Dash, Respray
    Mar 2013
    33
    Do they just plug and play then? How does it trigger the coil?
    Oct 2012
    Scotland
    237
    Yeah just plug and play, the TSi/FSi coils don't require an external ignition module, I assume it's built into each coil
    Fitted
    Koni STR.t Kit
    Awaiting Fitting
    Wanted
    Plans
    Mar 2013
    33
    Oh I see. That looks pretty cool.
    Did you buy certain type TSI/FSI coils or just any as I did see someone suggesting there were specific coil part numbers to buy?
    Oct 2012
    Scotland
    237
    I went for the red coil packs on PSI's website, you'll need the adapters too
    Fitted
    Koni STR.t Kit
    Awaiting Fitting
    Wanted
    Plans
    Dec 2008
    Bradford, West yorks
    27
    Now then...... had exact same issue, try looking at the breather valve under the inlet manifold, if its passing its pulling unmetered air direct into the inlet manifold, thus a lump idle mine was sorted straight away with this, bout £8 from the dealers so very cheap fix
    let me know how ya get on
    Pubemammal likes this.
    Pubemammal's Avatar
    May 2013
    Braintree Essex
    440
    Thanks for all your replies, lots to look at now and hopefully solve this! Cheers guys
    Nov 2013
    Uxbridge, London
    44
    I have had my A3 for a little over a month now, and have had exactly the same symptoms as you with the hunting idle when pulling to a stop. Until Saturday when it stalled after starting, and after getting it going - it sounded like crap. Turns out the spark plug in cylinder 3 is wet and doesn't seem to be firing.
    From what I've read on other threads, its either the coil pack itself, the Ignition Control Module, or the wiring from the ICM to the coil at fault. I am yet to find out which it is!
    Have ordered a code scanner which should arrive tomorrow to see if there is anything showing before I start replacing bits!
    Hope yours isn't about to do the same as mine lol.
    Pubemammal's Avatar
    May 2013
    Braintree Essex
    440
    Ok so I replaced all the spark plugs today to bosch 509's. Still didnt fix the idle. Whilst doing the plugs I found this...
    Any ideas what this hose is and if it would cause this hunting idle issue?
    Also one of the coil packs had a bit of an oil leak?
    Pubemammal's Avatar
    May 2013
    Braintree Essex
    440
    Problem solved! Cleaned the TB again today... very thoroughly. I also unplugged it, disconnected the battery then put it all back together, reconnected the battery, turned ignition on until throttle body stopped "buzzing", fired it up and joy! Idle is fixed. The new plugs and fixed idle has transformed the car. Thanks for all your input
    Pubemammal's Avatar
    May 2013
    Braintree Essex
    440
    Nov 2013
    108
    always do the free stuff first!At least its fixed
    JD09's Avatar
    Dec 2009
    Cheshire, Alderley Edge
    3,080
    Sorry to bump a week old thread, but interesting that your needle moves a tiny tiny amount, as mine does. I thought this might be a VAC leak, but have done all the above re TB, plugs, etc and it's no different. Car runs fine!
    Pubemammal's Avatar
    May 2013
    Braintree Essex
    440
    Quote Originally Posted by JD09 View Post
    Yeah it has always done this. Whilst doing the TB I noticed a hose near the bulkhead had been rubbing on some insulation and has a small hole in it! I'm guessing this could be why the needle moves a tiny bit and maybe why I get a hissing noise under heavy acceleration? Do you get the hissing aswel?
    JD09's Avatar
    Dec 2009
    3,080
    No hissing (loud enough to hear, anyway) but intend on replacing most of the vac hoses anyway, just as preventative maintenance.
    Pubemammal's Avatar
    May 2013
    Braintree Essex
    440
    Yeah good idea, I did replace my vac hose when I fitted the forge 007p... I actually think its the new recirc valve causing the hissing, it also whooshes on a gear change which is kind of crap... not sure if its supposed to or what!
  1. Had enough of this damned clock!
    By Vertigo1 in forum New A3/S3 (8V Chassis)
    Last Post: 23rd June 2013, 16:57
  2. Replies: 41
    Last Post: 28th September 2010, 14:18
  3. This was written by a guy... it's pretty damn smart.
    By Booth_S4 in forum Jokes, Games & Humour
    Last Post: 25th October 2006, 15:16
  4. This is so damn funny!
    By RichA3Turbo in forum General Chat
    Last Post: 17th February 2006, 14:54
  5. Damn, this car is great in the ice
    By Stormcatcher in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd February 2003, 19:24
