Volks AutosSky Insurance
Results 1 to 7 of 7
    Dec 2013
    32
    need help with vag codes
    got my car scanned today and the first scan threw up loads of codes cleared them went for a run now only got 2 codes car still only boosting 4psi
    00515 - Camshaft Position (Hall) Sensor (G40)
    30-00 - Open or Short to Plus
    16486 - Mass Air Flow Sensor (G70)
    P0102 - 35-00 - Signal too Low
    the codes before i cleared them was
    10 Faults Found:
    18010 - Power Supply Terminal 30
    P1602 - 35-10 - Voltage too Low - Intermittent
    17967 - Throttle Body (J338)
    P1559 - 35-10 - Fault in basic settings - Intermittent
    17735 - Knock-Control: Cylinder 3
    P1327 - 35-10 - Regulation Limit Exceeded - Intermittent
    17736 - Knock-Control: Cylinder 4
    P1328 - 35-10 - Regulation Limit Exceeded - Intermittent
    01262 - Solenoid Valve for Boost Pressure Control (N75)
    26-10 - Output Open - Intermittent
    00544 - Maximum Boost Pressure Exceeded
    35-10 - - - Intermittent
    17733 - Knock-Control: Cylinder 1
    P1325 - 35-10 - Regulation Limit Exceeded - Intermittent
    any help please
    dusty's Avatar
    Nov 2010
    nw england
    143
    Have a look in the stickies in the 8l section or have a look on Ross tech website hope this helps
    2001 s3, stage 1 amk, nogaro blue, bilstein shocks, eibach springs, forge adjustable tie bars, Red power flex dog bone bush, Awesome heavy duty clutch, 18" nouvalari alloys, ambient lighting, tt pedals, led side lights, led number plate lights, abt number plate surrounds, badger 5 tip, jetex filter, resonated milltek cat back exhaust, bailey dv,
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,927
    16486/P0102/000258 - Mass Air Flow Sensor (MAF/G70): Signal too Low
    Possible Symptoms
    ## Malfunction Indicator Light (MIL) ON
    ## Loss of Power
    Possible Causes
    ## Wiring and/or Connector(s) from/to Mass Air Flow Sensor (MAF/G70) faulty
    ## Mass Air Flow Sensor (MAF/G70) faulty
    Possible Solutions
    ## Check Wiring and/or Connector(s) from/to Mass Air Flow Sensor (MAF/G70)
    ## Check/Replace Mass Air Flow Sensor (MAF/G70)
    Special Notes
    ## In MY 1995-2002 (?) in Europe at VW-diesel-cars G70 had the bad reputation of slowly losing his performance, causing loss of power. It's not a matter of defective or breaking down, but it is filthy / dirty (not easy to clean). You can check functionality by making a log in [01-engine], [meas.blocks-08], group 003 (3e gear, full throttle, from 1700-4000rpm)
    00515 - Camshaft Position (Hall) Sensor (G40): No Signal
    Possible Causes
    ## Wiring to Camshaft Position (Hall) Sensor (G40) faulty
    ## Camshaft Position (Hall) Sensor (G40) faulty
    Possible Solutions
    ## Check Wiring to Camshaft Position (Hall) Sensor (G40)
    ## Check/Replace Camshaft Position (Hall) Sensor (G40)
    ## Check/Replace Engine Control Module
    Special Notes
    ## Some older engines store this code as long as the engine is not running, if in doubt read fault codes with the engine running again.
    00515 - Camshaft Position (Hall) Sensor (G40): Implausible Signal
    Possible Causes
    ## Camshaft Timing Out of Specification
    ## Engine Control Module faulty
    Possible Solutions
    ## Check Camshaft Timing
    00515 - Camshaft Position (Hall) Sensor (G40): Open or Short to Plus
    Possible Causes
    ## Camshaft Position (Hall) Sensor (G40) Installation faulty
    Possible Solutions
    00515 - Camshaft Position (Hall) Sensor (G40): Short to Ground
    Possible Symptoms
    ## Power Loss
    ## Emissions not OK
    ## High Fuel Consumption
    Possible Causes
    Possible Solutions
    Category: Fault Codes
    Categories
    Main Page
    Diagnostic Procedures
    Common Procedures
    Fault Codes
    Retrofitting
    Immobilizer
    Meta
    Log in
    bez101's Avatar
    Jul 2008
    7,927
    unplug the MAF take if for a run see if the power comes back
    Dec 2013
    32
    i will try that its the boost that im trying to solve
    bez101's Avatar
    Jul 2008
    7,927
    yes the maf can cause low boost
    Dec 2013
    32
    ok will try and see how i get on
  1. New Diff Fitted Today!!!! Need Help with 4 codes...
    By coopsS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th October 2010, 21:16
  2. need help with rnse coding on 05 a3 8p
    By bluequattro in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st September 2010, 22:39
  3. Need help with Fault codes please
    By xlr8 in forum VCDS (formerly VAG-COM) forum
    Last Post: 10th August 2007, 22:57
  4. Help with Vag code?00561 - Mixture Adaption limit not reached - Interm
    By imported_ChrisCardiffA3T in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th March 2005, 09:44
  5. HELP WITH VAG CODE! O2 SENSOR?
    By 97AUDIA418TQ in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th February 2004, 12:22
