Results 1 to 18 of 18
    Jan 2014
    Northampton
    S3 suspension upgrades
    Hey all,
    So I'm looking into getting an s3 and I should have a little bit to do some upgrades.
    I'm ruling out a map because I want to do some engine bits first.
    So I thought handling is a good place to start. I see a lot of you recommend the bilstein/eibach static setup from DPM, but they also do cheaper Koni and KW setups - is there really any worth in the extra cash for road handling? I won't be tracking the car or anything.
    Also was thinking of upgrading the bushes, but I'm not sure what brand, where to buy or what bushes to get.
    And is it worth uprated ARBs for 300 or would solid bushes and a static drop improve things enough?
    What are people running? Any recommendations?
    Oli
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,287
    Afternoon,
    The Bilstein B12 kit is pretty much the best springs and shocks kit on the market but is closely followed by the Weitec by KW Ultra GT kit.
    Match either of those with a set of uprated ARBs and you'd have a very good handling S3.
    It's also advised to get adjustable rear tie bars to keep the rear camber in check.
    Damian @ DPM Performance
    DPM Performance
    W: www.dpmperformance.co.uk
    T: 01207 561606
    E: sales@dpmperformance.co.uk
    Jan 2014
    Northampton
    cheers damian.
    in all fairness i'll only be commuting with occasional blast around the lanes, so it doesn't need to be amazing, just less woolley than standard 13 year old kit would be!
    possibly a koni kit, audi top mounts, defcon bushes and then replacement poly bushes all round?
    whats the deal with the adjustable tie bars? not heard of these before, are the AWD specific? i'd only be dropping it 20-30mm which shouldnt be enough to knock the camber out too much should it?
    mattyboy199's Avatar
    Nov 2005
    UK
    1,688
    20-30mm will throw the camber out so you will need adjustable tie bars. Bushes go for powerflex all round or similar except the front wishbone bush which should be kept OEM spec, its also worth replacing the drop links front & rear, ball joints, ARB bushes & top mount / bearings.
    Likely to cost in excess of £1000 for that lot including a spring/shock kit.
    2002 Dolphin grey S3 - Sym2+bose, heated leather, ally mirrors, R32 ARB's with superpro, Jabba stage 2 map, TFSI coils, Samco TIP, Forge DV & privacy glass
    2010 Green Kawasaki Ninja ZX6R - Akrapovic baffleless race can, LED cluster & HID's
    wanted for 8L S3:
    Unmarked grey rear bumper panel
    Milltek system
    dusty's Avatar
    Nov 2010
    nw england
    144
    I run bilstein shocks and -30mm eibach springs the ride and handling is superb as said above you will need adjustable tie bars to dial out the negative camber on the rear after lowering
    2001 s3, stage 1 amk, nogaro blue, bilstein shocks, eibach springs, forge adjustable tie bars, Red power flex dog bone bush, Awesome heavy duty clutch, 18" nouvalari alloys, ambient lighting, tt pedals, led side lights, led number plate lights, abt number plate surrounds, badger 5 tip, jetex filter, resonated milltek cat back exhaust, bailey dv,
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,681
    Another one with a B12 kit, been on the car for 9 months now and loving it. Also had it poly bushed at the same time. Got Neuspeed ARBs and Forge adjustable rear tie arms for camber correction (I had KW ones previously but one snapped - and I'm not the only one that's happened to). There is currently a groupbuy running for Dave's equivalent.
    Jason
    2001 Nogaro S3 (daily driver)
    1958 replica Porsche 356 Speedster (summer posing)
    1997 Seat Cordoba SX 16v (track day toy) replacing (t)rusty 1994 Seat Ibiza GTi RIP
    sssline's Avatar
    Apr 2012
    Essex/London
    135
    Quote Originally Posted by jcs356 View Post
    Did you do the rose joints and drop links too? Also for top mounts what did you use? Also how much drop did you get with the kit over standard? (Assuming its an s3) Thanks
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,681
    Quote Originally Posted by sssline View Post
    Will need to dig the receipt out.
    Jason
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    The route I took, again B12 based: New Year - new suspension!
    > S3 225 (03) - OEM+
    > 205 GTI (90) - Limited Edition Miami Blue with full leather - 1 of only 300 made
    > Clio v6 255 (05) - Lethal Weapon
    View: My S3 diary
    sssline's Avatar
    Apr 2012
    Essex/London
    135
    Quote Originally Posted by [Dave B] View Post
    Thanks Dave, how have you got on with it cos you're coming up to a year now? Is it comfortable for fast road and also can you possibly post a pic so we can see the stance please?
    Jan 2014
    Northampton
    Dave that set up looks good. Do you mind letting us into costs for it all? If you don't want to that's fine, no drama. Just out of interest.
    Would it be worth an R32 front ARB too? I've heard that Defcon bushes on the wishbones are a good shout too?
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    For my needs it's been spot on TBH. Firm but comfortable ride and the handling is in a different league to the standard setup. IMO it's low enough to look a bit meaner but still practical for carrying a full load and negotiating speed bumps and multi-storey car parks. It's not 'stance' low though. I'll get a pic tomorrow and post it up.
    Quote Originally Posted by marshole82 View Post
    I can't remember exactly but I've got a full breakdown of what I paid on a spreadsheet at work if you want a copy. I think it was about £1300 for the parts and laser 4 wheel alignment, I did the fitting myself over the course of a few nights. It sounds a lot but that covered pretty much everything including bushes, ball joints, TRE's etc so it should last as long as the car hopefully. IMO I wouldn't bother with the R32 front ARB as it'll just bring back some under steer that you dial out with the rear ARB. Defcon bushes might be worth it as there are good reviews for them but for me it was a step too far.
    > S3 225 (03) - OEM+
    View: My S3 diary
    Jan 2014
    Northampton
    Cheers dave a spreadsheet would be ace. I'll PM you my email for when you get chance.
    A pic would be decent too!
    sssline's Avatar
    Apr 2012
    Essex/London
    135
    Sounds about right in terms of costing.
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,681
    Sorry, haven't found the receipt yet. But agree with Dave about height. My car is higher than it was with the previous ABT springs on it (I can get off the drive at my mum's house without scraping the underside of the front bumper).
    Jason
    sssline's Avatar
    Apr 2012
    Essex/London
    135
    Yeah, I do want a 20mm drop over standard though so wondering whether I should chop the eibach springs for apex.
    Thanks though.
    AVLO's Avatar
    Mar 2012
    Doncaster
    268
    I have also been looking at a new suspension setup for this year. Im still toying with the idea of shocks and springs or coilovers what are the + and - to both??? Also I have a friend selling some solid subframe mounting bushes would these be worth a purchase??
    BRING ON THE WET WEATHER ​QUATTRO FTW
    Jan 2014
    Northampton
    Fixed drop like eibach will be better for handling. Only pro of coilovers in comparison is that they allow you different heights.
  1. Advice requested for S4 suspension upgrade
    By imported_druggie in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th April 2006, 07:57
  2. Suspension upgrade
    By sinbadfury in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 23rd February 2006, 21:23
  3. A4 1.8T 190 Sport (Gmbh) suspension upgrade?
    By SteveGi in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th July 2005, 19:20
  4. Brake & Suspension upgrade for A8
    By imported_WIL9598 in forum Handling
    Last Post: 11th August 2004, 11:15
  5. Replies: 1
    Last Post: 14th October 2003, 08:02
