JMB RetrofitsAH Fabrications
    dusty's Avatar
    Nov 2010
    nw england
    144
    Engine rebuild advice
    Hi everyone happy new year, I have a 2001 amk s3 that has been off the road for a couple of months with a bent con rod, I'm planning on building a new engine when I have collected all the parts together, I'm hoping to fit the tfsi turbo, forged rods, new piston rings, balance the bottom end and possibly port and polish cylinder head, I was wondering if it would be beneficial to fit agu pistons as these are higher compression and agu cylinder head as these are larger ports to my amk, or would it not be worthwhile with the tfsi turbo, I've read the agu parts aren't needed unless you are aiming for 450+bhp, but I would like to have the best performing engine for its spec, any input would be appreciated thanks.
    2001 s3, stage 1 amk, nogaro blue, bilstein shocks, eibach springs, forge adjustable tie bars, Red power flex dog bone bush, Awesome heavy duty clutch, 18" nouvalari alloys, ambient lighting, tt pedals, led side lights, led number plate lights, abt number plate surrounds, badger 5 tip, jetex filter, resonated milltek cat back exhaust, bailey dv,
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    I wouild fit them, because its prawns spec and his car responded well to the tfsi turbo
    dusty's Avatar
    Nov 2010
    nw england
    144
    Yea thanks Karl I've read through prawns epic build thread a couple of times I thought it would be better with the agu parts just wanted to be sure, is there anything else worth upgrading while I'm doing the build
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    Make sure the head gets a good refurb with guides, seals and a skim is all id say. If you have the time and money.
    I wanted to ARP everything on my engine for the hell of it but, funds wouldn't allow. Maybe do that if you have the cash.
    Mar 2013
    Devon
    616
    Are the AGU pistons found in the other large port engines? I have a AEB engine stashed at the back of my garage, planning to use the head, but not sure if anything in the bottom end is of use?
    dusty's Avatar
    Nov 2010
    nw england
    144
    I'm pretty sure all the ko3 based engines have the higher compression pistons
  1. Engine rebuild advice needed
    By patTTpoa in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th November 2011, 20:52
  2. engine problems advice needed
    By 20s on a tt in forum TT/TT-S/TT-RS Forum
    Last Post: 31st March 2008, 10:26
  3. New and need help - any contacts for an S4 engine rebuild
    By grgh in forum The Welcome Section
    Last Post: 14th March 2008, 19:30
  4. S3 ENGINE REBUILD!!
    By pault in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th July 2007, 09:31
  5. engine rebuild?
    By SQ_lover in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th August 2005, 01:43
