Results 1 to 22 of 22
Like Tree3Likes
  • 1 Post By Wallm0nkey
  • 2 Post By Wallm0nkey
Thread: S3 Car Alarm - won't stop going off
    Schlaag's Avatar
    Bwah
    Jul 2007
    Kent
    291
    Hi All. Happy new year.
    A nice new year woe for me!
    When locking the car (with remote and key) the door LEDs flash really fast and after 30 seconds the alarm goes off.
    The alarm also goes off if I leave the car unlocked
    Can anyone help me with possible causes? is it a common thing?
    Its a horrendously annoying issue as I have to keep disconnecting the earth terminal on the battery whenever parked up!
    Can I switch the dam thing off whilst I attempt a fix?
    thanks
    Dave
    2001 AMK Dolphin Grey S3
    May 2013
    Birmingham
    212
    Have you ever replaced the alarm siren? If not near enough guaranteed it is that as it's the same symptoms I had it is a common fault and an easy enough fix. It's caused by the battery backup inside the siren leaking and corroding the pcb, there is a revised part available from audi roughly £120 from memory. I need to replace mine still but had other issues to tend to!
    To stop it going off you need to remove the boot carpet and strip down the left hand side and remove the sub as the siren is buried down there you can then unplug and remove it. Obviously your alarm will no longer sound at all but the LEDs on the doors still flash so it appears to anyone else to work.
    Probably about an hour to strip out and get the boot back together and it's all posix rive screws from memory plus a few 10mm nuts.
    Schlaag likes this.
    May 2013
    Birmingham
    212
    If you scroll down this thread there is a removal guide: Westle and S3baby's late night mechanics. (Replacing Alarm Batteries)
    The Audi TT Forum :: View topic - How to - MK1 Alarm Siren fix That's a guide to replacing the battery if yours is salvageable. Mine was a little to far gone so gonna have to replace it I gather if it's bad enough to set the alarm off it's already dead. Worth 5 mins with a hacksaw to find out though!
    Nilz and Schlaag like this.
    Schlaag's Avatar
    Bwah
    Jul 2007
    Kent
    291
    Thank you guys, great info/help there.
    If it isn't the siren battery problem, are their any other ports of call to check? As if I remove the siren and the alarm keeps activating, the hazards are going to drain the battery fairly soonish
    cheers
    Dave
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,087
    Is the battery on your car ok?
    I had the issue on mine, as i believe the alarm senses a drop in voltage, which can cause it to trigger.
    Schlaag's Avatar
    Bwah
    Jul 2007
    Kent
    291
    Hi Nilz, I think the battery is fine. Never had any probs with it. Suppose I could stick a meter on it to check. Going to go check out the boot catch area now.
    Nilz's Avatar
    Apr 2006
    10,087
    Just read your post on the washer jet thread too, it maybe related to that you know.
    Nov 2011
    W. London
    63
    Dunno if this helps but does your interior light flash at all? I had a problem a while back when sitting in the car i noticed the interior light flashing but the dash didn't say the door was open, then alarm kept going off after 30 secs of being locked, slammed the passenger door a few times the light stopped flashing and i stoppped having the problem.
    Schlaag's Avatar
    Bwah
    Jul 2007
    Kent
    291
    guys which plug on the rear hatch is for the alarm sensor?
    just removed the siren and alarm still triggers (flashing the repeaters)
    Nilz's Avatar
    Apr 2006
    10,087
    Im not too sure...
    So now that you have removed the siren and locked the car, the led on the door flashes for a few seconds rapidly, then slowly yea??
    What happens then, does the alarm get triggered somehow and the indicators start flashing as if the alarm is going off, but now without the siren??
    Schlaag's Avatar
    Bwah
    Jul 2007
    Kent
    291
    Yes exactly that mate. Rapidly for a bit then a bit slower for 30 secs then once its armed, a slower pulse... then after a bit ... kaboom, flashers going off (alarm triggered) obi no sound due to removed siren.
    NOW.... I have unplugged everything I can see in the rear hatch bar the wipers and the numberplate bulb feeds.
    I've armed the car and nothing has gone off
    Thing is, i'm now too scared to disturb anything! I known, process of elimination and all that now you would think.. playing havoc with my nerves.. re arming the system and waiting for the inevitable flashing!
    It HAS to be boot sensor related.
    Ok, off I go again! :D
    Schlaag's Avatar
    Bwah
    Jul 2007
    Kent
    291
    Plugged one thing in. Alarm went off
    Unplugged it again
    Still went off
    epox's Avatar
    Oct 2012
    Glasgow
    584
    have you tried to switch of the ultrasonics? just in case its them. switch on driverside pillar
    mark
    S3 2003........REVO..........Stage 1...........218G/S.......÷..........°8..........=..........272bhp ......368Nm.....271 ft lbs
    Schlaag's Avatar
    Bwah
    Jul 2007
    Kent
    291
    Hi Mark, yes tried that. Still went off.
    If anyone near Maidstone/Paddock wood has VCDS, i will gladly pay some £ for a scan
    Nilz's Avatar
    Apr 2006
    10,087
    Sounds like something is shorting it somewhere in that case....very unusual!!!
    Have a look on the VCDS Users map to see if anyone is nearby to help mate.
    Schlaag's Avatar
    Bwah
    Jul 2007
    Kent
    291
    Guys, is the boot alarm sensor here (black plug with audi rings on top of lock )
    unplugging does nothing but perhaps it always needs to be plugged in?
    s3ajy's Avatar
    May 2010
    Aberdeen
    40
    Visit s3ajy's Instagram Channel
    Recently had the same issue with mine....replace the siren, then door switches (due to codes on vag com) both didnt cure the fault.
    Late night ebaying saw me buy a new central locking pump (located in the rear by the siren) replace that and job done!
    Again this was just for my car but seemed to of exhausted all other possibilities.
    Schlaag's Avatar
    Bwah
    Jul 2007
    Kent
    291
    Quote Originally Posted by s3ajy View Post
    Hi mate. Aaah the square foam covered box? two air pipes going in to it (blue and yellow) ?
    Funny you mention that, as the yellow hose connector on my one comes off very easily.
    Something to look at aswell I guess!
    why did you choose to replace that? did you have a fault with the central locking or just a random replacement in hope of fixing the alarm fault?
    s3ajy's Avatar
    May 2010
    Aberdeen
    40
    Random replacement.....but when i ordered it it all started to make sense.....the central locking pump wont register that all the doors are shut...hence the 30sec wait then the alarm going mental i bought second hand unit from ebay for 40 quid and crossed my fingers when fitting it.
    Saying that though.....these symtoms are also similar to a sirens internal battery dieing.
    When you lock the car does it chirp from the alarm?
    Good luck, i feel your pain!
    Schlaag's Avatar
    Bwah
    Jul 2007
    Kent
    291
    Hmmmm. I might try that then. From memory there are no electrics to this pump.. its just the vacuum hoses?
    Ive removed the siren but its never chirped, ever when locking/unlocking the car
    I've discounted the siren battery issue as even with is removed, the alarm keeps triggering.
    Will check out a local breakers for any A3's! thanks mate
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,450
    Quote Originally Posted by Schlaag View Post
    Try users A3kent or jaya3 for vcds scan near you. x
    s3ajy's Avatar
    May 2010
    Aberdeen
    40
    Not gaurenteeing this will cure the fault but it did on mine so worth some further investigating.
    Keep us posted
  1. Car alarm going off, and then key remotes forgotten!
    By MooLard in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th January 2014, 07:43
  2. Car alarm keeps going off
    By harris9053 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th February 2012, 21:14
  3. Alarm going off and couldnt stop it!
    By AudiiduA in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th September 2010, 01:17
  4. Help - Alarm randomly going off and not stopping
    By dpeilow in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th December 2004, 17:30
  5. Alarm going off for no reason
    By schuumi in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th November 2004, 13:09
