EM TuningJMB Retrofits
Results 1 to 10 of 10
Like Tree2Likes
  • 1 Post By Goubo1
  • 1 Post By superkarl
Thread: Turbo cool down time??
    Oct 2013
    N yorkshire
    65
    Just getting a new turbo fitted to my s3 and I am wanting to look after it from the start £££££ . What is the best way of cooling the turbo down after a drive and how long?? Would ya just sit and let it tick over for a couple of mins. Is there any thing you can buy to put on the car so the car turns the engine of it self have seen this on a Evo???? Carnt wait til get car back!!! ;-)
    Dec 2011
    630
    If I've been out ragging the car about on the last few miles on the way home I take it steady stay of boost then when I get to the house give it a min on idle
    s3_trev likes this.
    Feb 2012
    360
    Hi, on track or after a road drive we always run on low power for a few minutes to settle things down before stopping, then when stopped let the car tick over for 2/3 minutes or after a spirited drive 4/5 mins. Bearing in mind that we are running 380 brake.
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    The car is fitted with an after run pump as standard, and will circulate coolant to your turbo after you shut it off. Just make sure it works. Its located on the drivers side of the radiator at the top.
    In addition to that, DO NOT be boosting the thing when cold, always wait till the WATER is at 90, and even then oil won't be up to optimum temp, so build your enthusiasm gradually.
    And cruise gently for the last couple of miles.
    s3_trev likes this.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,602
    S3 has an after run pump to continue circulating coolant round the turbo for around 10mins after the ignition is switched off too... as said though if you have ragged it allow yourself a few mins of your journey to let stuff cool a bit...
    Don't even think about fitting a turbo timer... they are technically illegal...
    <tuffty/>
    s3_trev's Avatar
    Nov 2013
    Northern Ireland
    627
    I am interested in this as well actually, although I am running the standard KO4 on my '09.
    I suspected as much, is it audible after turning the car off? As I have heard a pump noise before and assumed that's what it was. Although I always let the car idle for a while before turning it off, if I have been driving hard.
    Audi S3 8P3 / REVO Stage 1 / REVO Ceramic Intake / NGK Iridium Spark Plugs / LOBA HPFP / Philips Diamond Vision 5000k Fog Light Bulbs /
    KW V3 Coilovers / Team HEKO Wind Deflectors / Bridgestone Potenza S001 92Y Tyres / Complete LED Bulb Conversion (int' + ext') / Ashtray Delete /
    TTS Engine Cover / Alpine 928r Multimedia Station (8in screen) with integrated Bluetooth, Sat Nav etc / Ross-Tech VCDS Owner.
    Oct 2013
    N yorkshire
    65
    Thanks for that will listen out for the pump not sure if heard it before it's been about 6 weeks since drove it like so have forgot really. Had enough of driving around in a 950 3 cylinder corsa just want my car back now.
    Dec 2011
    630
    After switching of stick your ear at the grill and you will hear it
    Oct 2013
    N yorkshire
    65
    Thanks!!
    Boost fiend
    Dec 2008
    Swansea
    215
    Does the 1.8T A3 have the after run pump?
    99' A3 1.8T Sport KO3s Custom Code stage 2 - Current
    99' A4 1.8T Quattro Sport 180 - Sold
    97' A3 1.8T Sport KO3s 236 BHP - Sold
  1. Run / Cool Down on a Turbo
    By brads in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th November 2011, 17:25
  2. Should I allow my turbo to cool down?
    By giblets46 in forum Diesel forum
    Last Post: 13th December 2007, 21:06
  3. Turbo cool down period?
    By Pontio in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th January 2005, 18:26
  4. Cooling down turbo cars?
    By recomdos in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th May 2004, 07:37
  5. Cooling down?
    By edwin98 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th July 2003, 10:05
