AH FabricationsBadger5
Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By <tuffty/>
Thread: Advice on brake upgrade
    Dec 2013
    12
    I need new brakes as the standard ones are crap. I like the LCR set up. How much do you reckon for the fronts and rears with red stuff pads and braided hoses?
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    879
    Add Vex182 on Facebook
    The rear brakes are beto be just left as they are, the front brakes seem to go for around £400 for a complete set.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    Dec 2013
    12
    I think the rear disk has warped so I would prefer to renew them. Who does these kits? Looking to do them in a couple weeks.
    Feb 2012
    1,132
    Thats a second hand price. Arent the rears the same as s3?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,575
    Quote Originally Posted by Baillie View Post
    What car have you got?
    <tuffty/>
    Dec 2013
    12
    <tuffty/>
    S3 8l w reg
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,575
    Std S3 brakes are 'ok' but your definition of 'crap' needs a little more info to be able to understand the context as even LCR brakes are 'crap' depending on how you use them and what pads/fluid you use...
    Before I changed to 4 pot calipers I used Motul RBF660 fluid and Ferodo DS2500 pads on A N Other discs and the brakes were night and day transformed... having 4 pot calipers with std pads and fluid may feel better initially but if you are a 'user of brakes' then they will soon go off like std brakes and you are no better off...
    As said, second hand LCR setups can be had for 400-500 quid, new/decent (I mean Brembo/AP Racing based kits) are a grand or more... there is a massive brake thread in the FAQ sticky at the top of this section... if you are on a budget then fit DS2500 pads, replace the fluid with Motul RBF 600 or 660 and just fit std pads/discs to the rear as they do no work anyway...
    <tuffty/>
    Dec 2013
    12
    I'm comparing them to my qs240 which had uprated pads. I think the are a bit shot tbh. The car shudders whilst I brake from a high speed but they are fine at low speeds. Thanks for the info. Going to book it in to my mechanic for a full service and brake replacements and fluids.
    Feb 2006
    Lincolnshire
    719
    As <tuffty/> says, the DS2500 pads do transform standard brakes. I had a set of them on my old A3 8L quattro (a heavy beast!) and I could not believe how much better they were, even with standard fluid.
    Maybe related, but that car was written off in an accident where I happened upon a stationary line of traffic on a dual carriageway, I stopped fine, but the new A5 Cabriolet behind me didn't.... My poor car... :o(
    I might look into these pads again for my S3.
    <tuffty/>, how much of that fluid you recommend would I need to replace the standard stuff please?
    Audi S3 - 2002MY - Denim Blue - Gone
    VW Polo GTI - 2011MY - Candy White - Here
    mattyboy199's Avatar
    Nov 2005
    UK
    1,688
    I dont plan to uprate my brakes but interested in zinc plated ones that wont rust from inside & on the edges
    2002 Dolphin grey S3 - Sym2+bose, heated leather, ally mirrors, R32 ARB's with superpro, Jabba stage 2 map, TFSI coils, Samco TIP, Forge DV & privacy glass
    2010 Green Kawasaki Ninja ZX6R - Akrapovic baffleless race can, LED cluster & HID's
    wanted for 8L S3:
    Unmarked grey rear bumper panel
    Milltek system
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,575
    Quote Originally Posted by Tooks View Post
    ....<tuffty/>, how much of that fluid you recommend would I need to replace the standard stuff please?
    Should get away with 2 x 500ml bottles for a full fluid change... don't forget the clutch shares the same fluid and is worth a bleed on a fluid change too
    I currently use ATE super blue fluid which is fine for road use imo... if you are hard on brakes though Motul would be better
    <tuffty/>
    Tooks likes this.
    Feb 2006
    Lincolnshire
    719
    Thanks <tuffty/>, I'll get myself some on order.
  1. A6 c5 front brakes upgrade advice
    By hughjass in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 29th September 2013, 22:12
  2. Small brake upgrade advice on S3 225.
    By Vex182 in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th June 2012, 22:48
  3. Advice on Brakes / upgrade
    By harmless in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 18th February 2010, 20:23
  4. 312mm brake upgrade advice!?
    By MAD_Adamski in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th November 2009, 12:09
  5. rear brake upgrade advice
    By dummi in forum General Technical / How To
    Last Post: 5th January 2006, 19:48
