AH FabricationsSky Insurance
    Dec 2013
    A3 1.8t quattro haldex intermittent problem
    Hi recently on a morning when I first start my car upon setting off
    the rear wheels are getting very jerky uneven power and is shaking the rear
    side to side. However after 30 secs- 1 min of steady warm up driving it's back as it should be.
    i have always kept up with haldex,filter changes and have had my rear diff oil replaced 20k ago.
    if anyone had any suggestions please help.
    anyone had this before? It has never just gone fwd nor does it scrub or make a noise on full lock
    at low speeds.
    Thanks ben.
    car is a 1999 model dbw but no esp/traction control :-)
    Jul 2013
    136
    Do you have access to vcds/vagcom..? A fault code scan might flag an issue up?
    cammage08
    Dec 2013
    Hi yes I have a local garage with vagcom I have a basic reader but nothing comes up I'm away till next Thursday so can't really get it checked out yet.
    Will be my next port of call I think damn car haha.
    Thanks for the reply
    A3 TQS
    Jul 2013
    Devon
    129
    You can also run the pump up with it and operate the controller using the output tests in vcds, oil and filter are due every 20k so probably due a change.
    Dec 2013
    Quote Originally Posted by rupe View Post
    Great thanks for that I shall ask my mechanic to perform a test for me whilst using vagcom.
    makes me want to shell out for vagcom although I would probably end up changing values n the car not start hahaha
  1. A3 quattro rear caliper problem
    By HOUCH in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th April 2009, 12:17
  2. New car, intermittent problem.
    By eagle_s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th January 2008, 13:39
  3. HELP!!!! HALDEX 4WD PROBLEMS
    By S3 ROCKS in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th September 2007, 18:04
  4. HELP HALDEX 4WD PROBLEM
    By S3 ROCKS in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd September 2007, 22:21
  5. intermittant problem
    By mastayoda in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th June 2007, 09:09
