Sky InsuranceVolks Autos
Results 1 to 21 of 21
Like Tree3Likes
  • 3 Post By Bad Sir Culation
Thread: Never easy....
    Nov 2011
    Leeds, UK
    287
    Never easy....
    Put the replacement headlights in, one sidelight bulb is dead, the other is doing a Morse Code impersonation.
    One of the dipped beam Xenons also didn't come on initially on one switch on of the lights. Fed up today.
    Halfords it is tonight then...
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,639
    Did you do a facelift conversion?
    Nov 2011
    Leeds, UK
    287
    It already has one. The lights it had didn't have back covers and the wiring was butchered.
    I've put it as close to a standard setup as I possibly could now. One of the HID ballasts has the full loom with it, the other doesn't and so I had to make a loom for the headlight wires to the ballast. Real ball ache.
    sean_s3's Avatar
    May 2009
    West Yorkshire
    264
    What are you needing , some D2S bulbs and some side light 501 bulbs ?
    S3 Big Turbo
    Nov 2011
    Leeds, UK
    287
    I'm good now. Picked up some 501 led's so off to try them.
    sean_s3's Avatar
    May 2009
    West Yorkshire
    264
    No probs . Is the car running better with the new stat ?
    S3 Big Turbo
    Nov 2011
    Leeds, UK
    287
    Not actually been able to take it out since changing it! It's still struggling sometimes when starting though and cutting out so not sure what's responsible for that.... Hope fuel pump is OK!
    I feel totally broken tonight. Should have been back on the road today and I am being held back by these lights. Took the flashing bulb out and swapped in a new LED. I now have no sidelight at either side. Swapped the other bulb too. No change.
    I tested the main headlight connector and two pins are showing just under 14v with the car running, the two remaining pins show 0.09v and 0.03v. I don't know what they actually should be?
    Nov 2011
    Leeds, UK
    287
    Actually, is it possible that the car doesn't like these led's somehow? I did also buy some regular 501 bulbs that I can try if need be, just didn't want to open them up and make them non returnable if possible.
    sean_s3's Avatar
    May 2009
    West Yorkshire
    264
    I may have some standard 501 bulbs lying about , I'll check tomorrow.
    S3 Big Turbo
    Mar 2013
    Devon
    613
    Quote Originally Posted by Bad Sir Culation View Post
    Expect you have already tried this, but have you rotated the LEDs 180 degrees in the bulb holders? being diodes they only pass current in on direction.
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,280
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    Quote Originally Posted by JimS3 View Post
    1 of my LED bulbs didn't work due to this.
    Quick 180 degree flip and it was sorted- hope yours is as easy OP
    2000 S3 APY
    18" BBS RSII with Michelin PS3s, 20mm H&R adapters, Relentless 3" DP and Sports cat, B5 V1 induction kit, cone filter+heat shield, Forge 007P, Awesome GTI SMF, AP coilovers, Facelift rear lights, Full Powerflex poly bush kit, R32 Rear ARB, SAI delete, N249 by-pass, Upgraded Engine mounts with Polytek, Stage 1 CC at Badger 5.
    s33nyboy12's Avatar
    May 2012
    East midlands
    1,388
    Don't give up mate! You will get there in the end...........:-)
    Sean
    Current: 2013 Audi A3 2.0 tdi s line 8V in black SD nav+ extras, E46 BMW M3, 1971 Volvo p1800, 2014 Ford transit sport 155ps ;-)
    Previous : Focus st 225 stage 1 (265 bhp and too much torque), 2002 audi s3 bam engine completely OEM, 2001 Audi a3 1.8 TQS 221bhp and about 20 other cars, majority civics ek4/ek9 and Bmw / Audi soot chucker's!
    Nov 2011
    Leeds, UK
    287
    I think I tried but didn't make a difference. I will double check by doing it again this morning.
    I don't need any of those fancy canbus compatible LED's for this car do I? These are just regular LED bulbs.
    Mar 2013
    Devon
    613
    Just standard ones. The side lights are not connected to the bulb check module so no resistor needed.
    Boost fiend
    Dec 2008
    Swansea
    215
    No, they aren't canbus. I put 501 LEDs on my car the other week after facelift conversion, and had no flickering.
    I have had a problem with passenger side headlamp not coming on first attempt, I took out the battery and battery tray yesterday and cleaned/greased all earths under there, and the positive lead going from battery to starter.
    Slow start and headlamp issues all sorted now! Worth a try mate.
    99' A3 1.8T Sport KO3s Custom Code stage 2 - Current
    99' A4 1.8T Quattro Sport 180 - Sold
    97' A3 1.8T Sport KO3s 236 BHP - Sold
    Nov 2011
    Leeds, UK
    287
    Quote Originally Posted by Nick101 View Post
    Cheers mate.
    There are earths under there?
    Nov 2011
    Leeds, UK
    287
    Well I've fixed the lights! At least I think I have. Have to see if that dipped beam gives me anymore trouble going forward.
    All these difficult DIY jobs have really come good now, as they have allowed me to gain the experience I needed to find the root cause of the sidelight issue.
    The bulbs were indeed in the wrong way.....
    sean_s3, kwistof and JimS3 like this.
    Boost fiend
    Dec 2008
    Swansea
    215
    Yea there are 2 earthing points under the battery tray, with 2 on each point.
    Worth doing as bad earths can cause all sorts of strange problems.
    At least the sidelights are working now!
    Nov 2011
    Leeds, UK
    287
    I currently have a problem with something constantly draining the battery. I'll look at these next. Cheers for that.
    kwistof's Avatar
    Jun 2010
    SE Kent
    2,280
    Cheap quick and easy fix then - result
    2000 S3 APY
    Nov 2011
    Leeds, UK
    287
    Yup, just feel ridiculous haha!
  1. Checking Transmission Fluid???? How? easy?!?
    By mspah in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st July 2004, 12:27
  2. something never discussed on here before...
    By paul_brad in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th May 2004, 22:26
  3. Fitting Wiring Kit for EXTRA Amp? Easy? Drilling?
    By mspah in forum In-Car Entertainment
    Last Post: 4th April 2004, 09:25
  4. Glovebox CD Changer How much?Easy fit?
    By Rolex1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th November 2003, 16:51
