Chris NottEM Tuning
Results 1 to 37 of 37
Like Tree7Likes
  • 2 Post By superkarl
  • 2 Post By audiholic ste
  • 1 Post By superkarl
  • 2 Post By s3dave
Thread: Fitment of FMIC, 76mm outlets, retain fogs.. reducer?
    ToonRing-G's Avatar
    Audi Virgin
    Jan 2013
    Renfrewshire
    59
    Hi folks, I have a 600x300x76mm Intercooler I got fairly cheap, and I'm looking to retain my fogs when I fit it, ive read over the large intercooler page and seen the various fitting methods and concluded that its going to be impossible to get 76mm hoses and keep the fogs, the only option is losing them.
    However, my question is, could I use a reducer down to say.. 60mm? and retain them that way? would there be enough space behind the bumper to have a 76mm-60mm reducer hose and keep my fogs?
    The only other option I can see is selling this FMIC and getting another one with smaller outlets, and id really rather avoid it!
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,451
    You haven't read the FMIC thread hard enough.
    All your options are included in that, including retaining fogs with reducers
    ToonRing-G's Avatar
    Audi Virgin
    Jan 2013
    Renfrewshire
    59
    a link to the specific page would be nice. nonetheless, its exactly the response I expected to get.
    Apr 2011
    Dublin, Ireland
    564
    Check the stickies section.
    AH Fab / Ebay / Forge S3/A3 FMIC installs (image heavy)
    You will find all known available info in that thread.
    B5 v1 Tip, Relentless v2 Manifold, Beach Buggy Hybrid, Pipewerx D.P and cat bypass, Miltek resonated cat back, AH Fabs v2 Intercooler, S2000 Filter, 83mm 9.5:1 CP Pistons, Brute Rods, Bosch 550cc Injectors, Oil Catch can, N249 delete, B5 Phenolic Gasket.
    H&R Springs, Koni FSD Shocks, s3dave's rear tie bars, LCR Brembo's, 18" ttrs alloys, replaced all suspension bushes, 15/20mm spacers front/rear.
    Now just waiting on my B5 exhaust manifold as the Relentless is goosed.
    ToonRing-G's Avatar
    Audi Virgin
    Jan 2013
    Renfrewshire
    59
    with all due respect guys, that thread is now 20-odd pages long and thus far, all I have found out is that it cant be done (westy used 90 degree 76-63mm joiners and couldn't retain fogs, well, couldn't keep the grilles) so I still cant see where the keeping fogs with reducers option is..
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,451
    You just answered your own query, westy kept the fogs. Not the grills.
    It was fogs that you said you wanted to keep.
    Essentially, to sum that thread up, if you're using a 300x600x76 core, you need welded outlets in order to keep fogs AND grills.
    Dani claims he did it with reducers, but I don't think anyone has seen his car and hes been a member since he was a featus.
    Dani_B19 and s3dave like this.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,169
    Lmfao @ karl. Paul, avlo and shaun have all seen my car and can vouch for the cooler lol, but yes I have fitted the wellycooler with 76-63mm reducers and kept the fogs, id dare say id be able todo it all in 76mm if needed but it isnt.
    Feb 2012
    718
    Slightly off topic but does the fmic need to be so big? Ive found an fmic with the dimensions recommended but with 63mm outlets. Saves reducing?
    audiholic ste's Avatar
    Aug 2013
    163
    I'm fitting the same fmic (welly cooler) well the same as Karl . Welding 63mm 90deg bends on and basically following the man of steels thread . Everything you need is in his thread . A question too Karl did you cut the bends down before welding them and is it worth pointing one down a bit and off setting them in the cooler . So I don't have to bend that bracket and so I don't have to cut as much away . I'm going to weld them myself so I'm open to suggestions .
    TomS38L's Avatar
    Oct 2013
    24
    Who needs fogs,shout about it I reckon ImageUploadedByTapatalk1388400062.388764.jpg
    Using Tapatalk
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,169
    Tom what coolers that? Also what size is the pipework?
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,108
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    Quote Originally Posted by ToonRing-G View Post
    There is a cooler out there with 600x300x76 dimensions and with 2.5" outlets. PM me if you want more info on where to buy it from as I don't think there available on ebay AFAIK.
    I'm still waiting for mine in the post
    Chris
    2000 S3 APY
    18" BBS RSII with Michelin PS3s, 20mm H&R adapters, Relentless 3" DP and Sports cat, B5 V1 induction kit, cone filter+heat shield, Forge 007P, Awesome GTI SMF, AP coilovers, Facelift rear lights, Full Powerflex poly bush kit, R32 Rear ARB, SAI delete, N249 by-pass, Upgraded Engine mounts with Polytek, Stage 1 CC at Badger 5.
    Dec 2013
    93
    Why do you need 3inch pipe work?
    63mm will support more than most need,
    500bhp easy.
    Feb 2012
    718
    You dont. Its just most coolers of that size have 3 inch outlets so you reduce down after.
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,451
    Quote Originally Posted by audiholic ste View Post
    I didn't cut the bends no. Il get some measurements for you as soon I can
    TomS38L's Avatar
    Oct 2013
    24
    Universal intercoolers but the kit is for an S3,it's spot on pipe work is 51mm to 60mm,find them on fb
    Using Tapatalk
    Aug 2013
    163
    Cheers pal . I read in another post of yours that you would like to learn to weld . I've been welding for 20 years stick gas mig and tig welding if you ever want a few lessons I would be happy to help . Got loads of scrap you could play with .
    Dani_B19 and superkarl like this.
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,451
    Quote Originally Posted by daz-20vt View Post
    this would be perfect!
    Dec 2013
    93
    Sorry I actually miss read a few posts lol!
    I'm going to be looking for a cooler shortly, originally I was going to go for the ah one, I probably still will, but I'll be looking to see what's out there as well,
    If you know some one with the tig gear can always cut the outlets off and weld on 63mm outlets.
    Feb 2012
    718
    Im in the annoying situation i cant change to an fmic until my insurance ie due for renewal. Admiral dont cover them. Ill see if i can source a link for the fmic i saw
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,451
    The thing with using silicone on the outlets of a core, 63 or 76, is that the silicone is a good 3-4mm thick.
    It will never be as good a solution as welded on pipework like the AH or like some of us have done with the wellycooler.
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,512
    [IMG][/IMG]
    [IMG][/IMG]
    Thats with reducers.. The best i could get it!
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,451
    Ahhh yes, I remember complimenting you on a good job at inters G!
    Gops likes this.
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,512
    Thanks Karl! I remember that sunburnt day! Next year im bringing sun cream, you can rub it on my back lol
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,451
    You can sod off! Lol
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,512
    hahahaha! im going on the strip next year! But back to the thread.. I had to trim the grilles abit to make it fit as much!
  28. #27
    Sep 2010
    Devon
    752
    I got my 90's welded on to my welly and kept the fogs, grilles and everything looking oem. It was really really easy. However much I'd like to claim genius status for this I ruthlessly stole it from Karl's thread, cheers Karl
    Badger 5 tuned 340 bhp / 350 lbft sleeper
  29. #28
    Feb 2012
    718
    My last s3 i had in 2005 had a universal cooler. Was a 550x280x65 core with 63 outlets. This made me able to fit silicone joiners to the cooler instead of silicone 90's. Then i used an alloy 45 (i believe) like karl says the outside diameter of alloy is much less than the silicone. I kept my fogs and all grills (grills needed sanding the back off a touch) but it looked completely oem. But from what i research now most would say that the cooler i used was too small. A mate logged the car and he was impressed with all the results. Any thoughts?
  30. #29
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,062
    Our good friend mr Beach Buggy now sells just that karl!
    BBT now sell a cooler which uses the same core and end tanks as the welly cooler, 600x300x76, but with 63mm inlet and outlets
    Perfect for anyone wanting to save vital space retaining fogs and grills, and works out at a similar cost to buying the wellycooler core and reducers anyway, so it's a no brainer for anyone concerned about looks.
    You all know where to find him too search beachbuggyturbos on facebook
  31. #30
    ToonRing-G's Avatar
    Audi Virgin
    Jan 2013
    Renfrewshire
    59
    thanks guys, just shows that a bargain aint really a bargain if its going to turn into a complete ball-ache to get the fit I want! so either I'm getting pipes welded on, or the FMIC is getting sold on and i'll just have to get another one! baws!
  32. #31
    Feb 2012
    718
    Is bbt only on facebook? Im not on it as its the root of all evil. I found one overall sizes 790x300x75 with 63mm outlets under a ton. But would favor something tested.
  33. #32
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,062
    Dan isn't just on facebook no mate, he's also on here as BeachBuggy, or if you have no joy drop me a PM and I'll sort you out an e-mail address and phone number
  34. #33
    Aug 2013
    163
    Karl if you could have a look and see what size pipes you used I know there where 63mm o/d but what length where they . Might get a week off soon and try and get a shed load of work done to the car .
  35. #34
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,059
    Needs to be 930mm gap internally so the 90 degree hard pipes need cutting down yes and point them down slightly then you miss a bracket
  36. #35
    Adam P's Avatar
    May 2012
    Southampton
    320
    I am following Vrbobs FMIC build currently, which is allowing me to keep my fogs and grills. Heres a link
    FMIC fitted :)
    2001 Audi S3 8L Ming Blue - LOST THE ROD LOTTERY BIG TIME (Rebuild underway)
  37. #36
    Aug 2013
    163
    So is that 930mm between the pipes or the center of the pipes cheers Steve
  38. #37
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,059
    Between the pipes O<.........930.........>O
    superkarl and audiholic ste like this.
  1. What fitment are the fog lamp bulbs?
    By AidenUK in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th November 2011, 11:13
  2. Fmic + fog lights
    By indiemike in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th November 2009, 12:46
  3. Ebay Fmic Fitment guide
    By Plunky in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th August 2009, 16:26
  4. fmic fitment a3 tqs
    By bansheeboyo in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th July 2009, 20:48
  5. Front Fog Light Fitments
    By Nilz in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th March 2008, 15:45
