Volks AutosEM Tuning
    Dec 2013
    32
    need help found oil in places it should not be
    took my spark plugs out today and they are covered in oil could this be why im geting 3-4 psi boost its a 97 a3 1.8t
    how do i fix this
    Jul 2011
    Berkshire, Surry, Hampshire tri-intersect
    353
    if it's only on the ceramic body I'd imagine it's just from the cam cover gasket... If there was that much oil in the cylinder you'd either be running very smoky or there'd be a rather noticeable misfire from a wet spark plug
    Dec 2013
    32
    well i blew the turbo 2 weeks ago still smoking but not that much its running bad right now only have 4 psi boost
    Dec 2013
    32
    there was oil dripping off the end of the plugs but i dont know if tha because i took them out and there was oil in the holes
  1. Is this the 'Oil Temp' warning light? Also, need help with other stuff!
    By lloydsta101 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th October 2011, 17:08
  2. Need help with oil cap problem
    By audi-tk in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th April 2011, 17:39
  3. Major VCDS Help, I changed the coding i should not have!
    By johal87 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th January 2011, 17:31
  4. need help problem with boot opening when car not locked
    By roger1985 in forum General Technical / How To
    Last Post: 3rd October 2010, 22:19
  5. Brakes pad /oil pressure - confuse need help
    By jaceyq in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 8th August 2010, 05:58
