Volks AutosMonster Motorsport
    Nov 2011
    Leeds, UK
    287
    Any consequence to using a non stretch bolt for one of the dogbone bolts?
    I have already done this, but thought I'd check while I remember.
    I bought new bolts for when I replaced my dogbone bush with a red powerflex item. I tightened to the torque setting I found on one of the forums, 40nm (for the two different length bolts) and then a quarter turn. I didn't quite reach a quarter on one of them when I felt that horrible feeling of the bolt threading the hole and going loose again.
    When I removed it again, it brought some of the thread out with it. I did manage to find a slightly longer bolt which I have now replaced it with as it managed to find enough thread for me to torque it to 40nm.
    Should I just leave it now and forget about it, or should I expect issues?
    Nov 2013
    Heath Hayes
    951
    How long is a piece of string. I would give it a week or so and check it's still tight at 40Nm . If so you are probably good.
    Karl.
    Karls 312bhp A4 3.0 TDI build thread http://www.audi-sport.net/vb/audi-s4...ld-thread.html
    RIP S3dave
    May 2004
    nr Glos
    7,162
    torque angle on old gear is flawed imho (unless head bolts) as the threads are so often corroded and the dogbone stuff corrodes like a mofo from galvanic corrosion... steel bolt, ally housing etc...
    "feel" overrides factory torque angle for me.
    Choose a 10:9 grade bolt but if the captice nut bits damaged you will struggle to get it tight
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    Nov 2011
    Leeds, UK
    287
    Checked this a week or two ago and it was OK. I am going to check again this weekend as it's now been about a month so if it's still tight I will stop worrying about it.
    Re: steel bolts/ally housing, had this on a set of Brembos once. The bolt welded to the caliper and the whole thing ended up having to be helicoiled!
  1. Replies: 13
    Last Post: 28th January 2014, 15:09
  2. Anyone any experience of using Blackcircles.com for tyres
    By h5djr in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th May 2008, 00:47
  3. any downsides to using the revo sps2 device too much?
    By jediknight in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th August 2006, 10:36
  4. Anyone used this net compnay before for new tyres?
    By sinbadfury in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th December 2005, 22:30
  5. A turbo for people that want a bolt-on solution-
    By R1GTI in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th June 2004, 23:47
