JMB RetrofitsVolks Autos
Results 1 to 25 of 25
Like Tree1Likes
  • 1 Post By Lavis89
Thread: Changed my thermostat - What a mare
    Nov 2011
    Leeds, UK
    287
    Well that was a fun job.
    It's done now, but I will probably be doing it again in a few months as money troubles meant I had to go for an ECP stat this time.
    Will see if it has cured my erratic temp issue when I next drive the car. Fair few jobs to be done tomorrow before I can do that though.
    Luckily the dipstick tube didn't give me any hassle, and I didn't touch the alternator. I ended up using a small 1/4" ratchet and 10mm socket on the bottom thermostat housing bolt. I am just hoping I managed to get it tightened up enough when putting it back together. Paranoia has really set in now, especially after the day I've had.
    I'm going to get this bloody car sorted if it's the last thing I do.
    Tomorrow I am swapping out the knackered/butchered headlights and replacing the tie rods and tie rod ends. I'm sure that will be fun itself!
    CazzaVR's Avatar
    Sep 2013
    Gloucestershire
    174
    Good work mate- keep going with it!
    epox's Avatar
    Oct 2012
    Glasgow
    600
    Satisfaction mate!!!! Better than paying a garage 40_50 £ per hr
    S3 2003........REVO..........Stage 1...........218G/S.......÷..........°8..........=..........272bhp ......368Nm.....271 ft lbs
    Aug 2011
    Plymouth
    762
    Add Lavis89 on Facebook
    Took me the best part of a year to get mine running smoothly, worth it when you get there, then you start spending all your money on mods instead
    Tsportaudia3 likes this.
    2001 1.8T Quattro Sport 89k covered ARY engine.
    Remapped at Badger 5, 213bhp - 235lb/ft torque.
    HS2K cone, FMDV008, Silicon TIP, 18" RS4 (reps), AP coilovers, Catch can, n249 bypass, Vent pod boost gauge, Toyosport 3" Downpipe/Decat, S3 Front brakes, Polyflexed Dogbone, S3dave (RIP) adjustable tie bars, FMIC
    Soon to be done: SAI delete, 3" Catback, Stage 2 remap
    Nov 2011
    Leeds, UK
    287
    Absolutely. I was supposed to be spending my money sorting a few issues on my 535D but it's all going into this thing at the moment.
    Still worrying about that bottom bolt not being tight enough, but it will be. I really am just a worrier.
    Going back out for the next job in a sec.
    Boost fiend
    Dec 2008
    Swansea
    215
    Done my mates on his TT yesterday, was harder than my A3, seemed a lot less room.
    Very satisfying to do, once I had sat down and warmed up.
    99' A3 1.8T Sport KO3s Custom Code stage 2 - Current
    99' A4 1.8T Quattro Sport 180 - Sold
    97' A3 1.8T Sport KO3s 236 BHP - Sold
    Nov 2011
    Leeds, UK
    287
    I actually found that using a 1/4" ratchet and 10mm socket was FAR easier for the bottom bolt than anything in any of the guides I read.
    Just waiting for the car to get upto temp now with the lid off the coolant tank....
    mattyboy199's Avatar
    Nov 2005
    UK
    1,689
    you can also use allen keys for the thermostat housing bolts
    2002 Dolphin grey S3 - Sym2+bose, heated leather, ally mirrors, R32 ARB's with superpro, Jabba stage 2 map, TFSI coils, Samco TIP, Forge DV & privacy glass
    2010 Green Kawasaki Ninja ZX6R - Akrapovic baffleless race can, LED cluster & HID's
    wanted for 8L S3:
    Unmarked grey rear bumper panel
    Milltek system
    Nov 2011
    Leeds, UK
    287
    Tried that but couldn't get good enough purchase on the bolt. The hole for the allen key was gunked up too much.
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,096
    Good work mate.....keep it up!!!
    Nov 2011
    Leeds, UK
    287
    Finally managed to have the car out today and the temp stuck at 90 all day. Very pleased with that!
    Need to find out what's causing the hunting revs/occasional cutting out now!
    May 2013
    Birmingham
    212
    Has been a couple of weeks since I've done mine and still appears well I had the same worry about not getting the bottom bolt tight enough! I have a very slight blip on idle I haven't tracked down yet hardly noticeable but bothers me when I'm waiting in the car. Need to get the sump cleaned and dogbone changed first your thread has spurred me on a bit!
    Dec 2013
    131
    I need to get round to doing mine, where did you guys get yours?
    I think mines stuck as I barely ever go over 65-70 on the gauge even in traffic.
    May 2013
    Birmingham
    212
    Mine was from Pw Europarts as they are local and helpful in there but if you have an Audi dealer local it should be in stock. I took the chance to swap my coolant too so grabbed two bottles of G12 while I was there.
    Nov 2011
    Leeds, UK
    287
    Got mine from ECP. I know people recommend genuine ones but £10 vs £27 on out for me this time. I've already spent up on the rest of the car!
    joe27's Avatar
    Jan 2014
    Kernow
    19
    Newby alert!!!!
    For my life, I can't get to the bottom bolt! Only way I see thro it is removing inlet manifold or slackening alternator off (a lot!). Peeps on other threads say its a 30 min job & in the dark ermm: T.B.H I wouldn't even know how to slacken the alternator off. I've replaced the oil stick sleeve so that's no prob to get on & off. I also noticed some perished vac rubber vac hoses when I slackened off the metal plate (I'm guessing these are my air hoses for vac pressure!?). You make it sound so easy but its opened a small can of worms for me so far!
    Its still running as before but my pride is hurt now I've serviced my previous cars no probs. Thermo won't come off this one though! Is the best way to remove the inlet manifold? My gasket needs replacing anyway & plugs are due for a change too, the coils are old too so may well shatter when I remove them - Should I "go for it" and do the thermo; rocker gasket, plugs & coils (if needed) all at once ??
    Opinion is MASSIVELY appreciated
    epox's Avatar
    Oct 2012
    Glasgow
    600
    do a search for me, i posted some pics (from an oter site to be fair) and it gives you info. i have done mine with 10mm socket and small ratchet from halfords pro set,
    mark
    dusty's Avatar
    Nov 2010
    nw england
    144
    It's not a big job to change inlet gasket, if you're struggling changing the thermostat it will be easier to get at the thermostat bolts with the inlet off, I used a 1/4 drive socket set to Change my thermostat
    2001 s3, stage 1 amk, nogaro blue, bilstein shocks, eibach springs, forge adjustable tie bars, Red power flex dog bone bush, Awesome heavy duty clutch, 18" nouvalari alloys, ambient lighting, tt pedals, led side lights, led number plate lights, abt number plate surrounds, badger 5 tip, jetex filter, resonated milltek cat back exhaust, bailey dv,
    Jul 2011
    Berkshire, Surry, Hampshire tri-intersect
    456
    I did my golf 1.8t and my mums 225 TT the other Saturday with out too much bother... Just used a 3/8 ratchet with extension, wobble joint thing and 10mm socket on the end of that... Deffo shouldn't have to touch the inlet or alternator!
    Also, on the coil packs, they're on recall with Audi. If they're still all genuine VAG coil packs in there then you may be entitled to get them swapped out for free
    joe27's Avatar
    Jan 2014
    Kernow
    19
    Thanks.
    Quote Originally Posted by dusty View Post
    Please bare with me fellas, my internet is running on a mobile dongle right now & connection is p** poor (its taken 15 mins to send this msg!). I appreciate both your replies. Need my internet back on though. Hopefully i'll be able to tap into your knowledge when I'm up & running properly - its all breaking down at the mo
    joe27's Avatar
    Jan 2014
    Kernow
    19
    Mmmmm! Inlet & alternator are v. close doing this, with the ratchet & extension between the 1 & 11 inlet exhaust its not possible (with my ratchet) to get one 'click'. Maybe I need professional tools with closer ratchet mechanisms etc Maybe I'm bordering being stupid & shouldn't attempt mechanical repairs
    I promise to keep the thread updated whatever I do! Cheers for the help though, I'd be completely stuck without it
    May 2013
    Birmingham
    212
    Long extension and wobble worked for me!
    joe27's Avatar
    Jan 2014
    Kernow
    19
    Cheers I'll get to grips with my extensions & wobbles in the morning Oil change 1st thing then need to check oil pressure.
    More questions there: where is oil pressure test port on 18t '99 ajq?
    joe27's Avatar
    Jan 2014
    Kernow
    19
    I'll get n upload some pics when I've been thro it all, it may help more peeps in future - rckn you guys are more advanced & on to better things than this, cheers anyway!
    Nov 2011
    Leeds, UK
    287
    I found with mine that getting a socket onto the bottom bolt with an extension was just impossible.
    I used a little Halfords 1/4" ratchet with a tiny extension and 10mm socket.
    Don't forget you can also try a 5mm Allen key but it might not go into the hole on the bolt very well if it's full of crap.
    Read up on an alternator replacement to see how to slacken that off if you really need to. It's only two bolts, but you should be able to avoid that if you just use a small socket.
  1. 2.5tdi changing thermostat - whats involved?
    By mystic.bertie in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th February 2013, 18:22
  2. changed quatrro fluid! WHAT A DIFFRENCE!
    By AVUSSILVER in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th January 2008, 08:01
  3. Changing the thermostat, HOW???
    By Prawn in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th November 2007, 18:24
  4. Changed the thermostat today.
    By S3 Dave in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th November 2007, 14:46
