EM TuningMonster Motorsport
Results 1 to 7 of 7
    May 2013
    Birmingham
    198
    Snapped clutch pedal!
    Just about to pull out of a big cross roads clutch goes straight to the floor... Had some people stop and help push me to safety and got in the pedals with a torch and it appears I've had the common snapped pedal. I managed to stick aload of cable ties on it to drive the few miles home. The housing for the white clip has gone strangely no bits on the floor? Can't find the metal anywhere and it seems I didn't have the black plastic clip that meets the clutch switch?
    I found the guide on here so will have a look at swapping it but could do with knowing where to get the parts from? I'll try pw europarts who I normally use but want to get sorted ASAP! So any pointers as to where will stock it are greatly appreciated I'm near birmingham and don't have access to tps. I gather I need the pedal assembly the black clip for the switch and the rest I can swap over.
    Thanks in advance people!
    Mar 2013
    Devon
    394
    Get the old pedal welded up for a long term fix. New pedals still have the same fault, insufficient weld.
    May 2013
    Birmingham
    198
    I did plan that but the piece of metal doesn't appear to be there... I was intending to get the new one welded up for piece of mind. I read about this failing when I had my bora been lucky til now!
    Banana Armour
    Aug 2009
    Leicestershire/Oxfordshire
    171
    Visit aterro's Instagram Channel
    Anyone got a picture of a welded one?
    So I can see how much is done.
    Apr 2007
    140
    If you are struggling drop me a PM as I have complete clutch pedal with master cylinder, much easier to swap over than mess around with the spring - you will realise that tomorrow if you just buy the pedal.
    I am in Sutton Coldfield but will be around Castle Brom if that's any closer to you.
    Otherwise just go to TPS in Aston. They will serve you - serve me all the time. I doubt ECP will have it.
    MK1 Leon Cupra R: K04 Hybrid / AEM WMI / Wellycooler / Mocal Oil Cooler / Superpro Polybushed / Vibratech Mounts / KW V3's / Factory Recaros / 330bhp...
    May 2013
    Birmingham
    198
    Audi halesowen had the parts in stock so a 5 min drive for me! New pedal fitted I managed to get the spring in a pair of adjustable grips and place it in to position seemed to go a little too easy after messing about with a cable tie!
    Here's the old one and why I couldn't see any broken bits:
    I'm going to get this one welded up and keep it as a spare but needed a quick fix so fitted the new pedal for now. Thanks again people!
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    9,640
    Glad you got it sorted, mine went recently too and got the whole thing replaced.
  1. OMG Clutch Pedal Just snapped.
    By Mr.G in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th June 2010, 22:28
  2. Clutch pedal snapped
    By campbell in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th September 2009, 17:25
  3. F****ng Stuck - Clutch Pedal Snapped.
    By Dani_B19 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th July 2009, 09:58
  4. Clutch pedal.... click, snap, drop!
    By markyp2002 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th January 2009, 00:01
  5. Clutch pedal snap
    By steve123a in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th October 2008, 20:08
