JMB RetrofitsVolks Autos
Results 1 to 7 of 7
Thread: oe dump valve
    Oct 2012
    birmingham
    246
    oe dump valve
    ive got this issue with my oem dump valve it sounds like a knackerd stearing pump and makes a horibble humming noise some times when driving is it broken or on its way out, i dont have any boost issues car is a 1999 s3 apy thanks
    May 2013
    Channel Islands, Jersey
    82
    if its the same noise i had, which was only on low boost at slow speeds then its annoying and chuck it out! I bought a second hand 007p DV, cleaned and oiled it was perfect (loads of threads for that). A brand new OE one is apparently just as good, so the choice is yours.
    Hope that helps.
    Audi S3 AMK, Badger 5 Tip with Cone and Heat Shield, Forge 007P (green spring), de-cat pipe
    Oct 2012
    birmingham
    246
    thanls
    Oct 2012
    birmingham
    246
    thanks
    epox's Avatar
    Oct 2012
    Glasgow
    600
    GOTO vaglinks.com then Miscelaneous DIYs and you can download a PDF showing you how to test dump valve.
    Mark
    S3 2003........REVO..........Stage 1...........218G/S.......÷..........°8..........=..........272bhp ......368Nm.....271 ft lbs
    Oct 2012
    birmingham
    246
    it sounds like power steering pump with no fluid in it at low boost
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    If it's shot then it's shot. There isn't a great deal you can do to service the OE DV. It's a diaphragm and once gone it's gone. How ever, for 19 quid, just buy another and replace.
    Thats the only real way to prove it's the DV making the noise to be honest.
    Homer Simpson
  1. Best Diverter Valve/Dump Valve
    By ScottyKemp in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd September 2003, 13:11
  2. Dump Valve/recirc valve?
    By Jinx in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th August 2003, 23:53
  3. Blow off valve or Dump valve ?
    By K212 in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th July 2003, 19:18
  4. Dump valves
    By waynehiscock in forum General Technical / How To
    Last Post: 28th March 2003, 18:15
  5. Diverter Values/ Dump Valves
    By Banwell in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th January 2003, 23:50
