aterro
S3 YO
Right.
to cut a long story shorter.
i went to place the CD changer back into my car ( S3 8L 2001 amk)
There was no cd changer cable.
So today i went to the head unit, use the two keys ( the ones that are like this- Below link)
PC5-93 Audi TT A3 A4 A6 Stereo Radio Release Removal Extraction Fitting Keys | eBay
now it just will not pull out.
So i left it, and went home. Then my cd player didn't turn on after trying to get it out with the keys) No lights or no response
So i got home, removed glovebox for access to the back. but even when pushing it from the back, it just will not budge forward! ( access is tight)
Then i removed the lower steering panel, access is even worse this side.
How can i get this out?
How do you remove the front fascia panel around the headunit?
or the panels on the outside of the headunit, aircon panels?
Any ideas would be great as i need to remove it, and hopefully get it working. My main aim was to check if the cd changer cable was there. Currently connected is a connect2 silver box for aux cableâ¦â¦.
