EM TuningChris Nott
Like Tree1Likes
  • 1 Post By Lewis583
Thread: Fault code 00290 ABS Light on
    Jan 2013
    Wiltshire
    Bought myself a cheap diagnostic tool off ebay when my abs light came on last week while driving on the motorway. Plugging it in, it shows fault code 290
    Which in the provided booklet says that this is the wheel speed sensor on the right rear, believe to be offside rear
    The sensor looked pretty grubby and was a pain to get out but this is now changed for a new one, used the diagnostic tool again, cleared the fault but as soon as it says clear, the abs light goes out and then straight back on again
    I haven't driven the car forwards yet, but it was also beeping at me when you drive away and shows permanently the brake warning in the central display on the dash.
    What else can I check/do?
    Merry xmas
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,018
    00290 - Ross-Tech Wiki
    00290 - ABS Wheel Speed Sensor Rear Left (G46)
    00290 - ABS Wheel Speed Sensor Rear Left (G46): Signal Outside Specifications
    00290 - ABS Wheel Speed Sensor Rear Left (G46): Electrical Fault in Circuit
    Possible Causes
    Open Circuit in Wiring from/to ABS Wheel Speed Sensor Rear Left (G46)
    ABS Wheel Speed Sensor Rear Left (G46) faulty
    Possible Solutions
    Check Wiring from/to ABS Wheel Speed Sensor Rear Left (G46)
    Check ABS Wheel Speed Sensor Rear Left (G46)
    00285 - ABS Wheel Speed Sensor Rear Left (G46): Mechanical Malfunction
    Possible Causes
    Excessive Air Gap between ABS Wheel Speed Sensor Rear Left (G46) and Rotor
    Short Circuit in Wiring from/to ABS Wheel Speed Sensor Rear Left (G46)
    Possible Solutions
    Check ABS Wheel Speed Sensor Rear Left (G46) Installation
    Have you checked the sensor ring in case its bent/damaged?
    <tuffty/>
    Last edited by <tuffty/>; 24th December 2013 at 14:56. Reason: DOH!... skim read fail!
    Jan 2013
    Wiltshire
    So is the book wrong or is the website? Two completely different sides.....
    Lewis583's Avatar
    Mar 2010
    830
    Your book is wrong, Autodata also says NSR (left rear).
    When you remove the NSR sensor, check to see if there is any damage to the sensor pick up area. Doesn't take a lot for the pick up ring to get damaged/corroded and take a chunk out of the sensor.
    <tuffty/> likes this.
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,018
    Good spot...
    <tuffty/>
    Biggied's Avatar
    They called him mellow yellow.
    Feb 2006
    Scotland
    202
    The fact that the fault pings straight back would suggest sensor or wiring rather than anything mechanical with the pick up ring or air gap, mechanical faults like that on the old A3 abs system will only reapear when the car has been driven after codes cleared. Also if Ross Tek Wiki and AutoData both agree on the same side them trust them together over anything short of a dealer Vas tool.
    Ewan. (Merry Christmas)
    210hp 8L S3 quattro.
  1. Fault Codes - Engine Management Light :(
    By leeds2592 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st May 2013, 14:44
  2. "Air Bag Light on" What is this Fault Code ? Help ?
    By Digzz in forum VCDS (formerly VAG-COM) forum
    Last Post: 26th January 2011, 17:12
  3. Replies: 2
    Last Post: 19th December 2010, 20:41
  4. ABS fault code
    By bengal in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th November 2010, 17:36
  5. Fault code 0287 008 / 012 ABS sensors- any ideas?
    By Prawn in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th April 2010, 19:01
