Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By mark_S3
Thread: Blowing out oil :(
    AVLO's Avatar
    Mar 2012
    Doncaster
    276
    Blowing out oil :(
    Hi guys, after having my atmospheric catch can fitted for nearly 12 month post remap about a month ago it has started to blow oil out of the filter on the top of the catch can. From observation from drive to drive I have noticed it only seems to blow oil out heavily under hard driving. The car did get a service just before the remap with new filters and oil but I didn't fill the oil myself although an experienced car technician did. I have checked the dip stick and it is level with the full mark. My only conclusions are that a. It has too much crankcase pressure, b. there is too much oil, c. It's coming from the head.
    Has anybody else had a problem like this before? The car is a S3 apy engine with 66,000 miles on it with a custom catch can that I bought off andrew@ald. It has 2 19mm inlets on the side and a top atmospheric breather.
    thanks matt
    BRING ON THE WET WEATHER ​QUATTRO FTW
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Ano its a daft question but is the can full?
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,469
    Its not a custom
    Just baffles added to a BSH catch can
    Where is it mounted in the bay?
    RIP S3dave/David Marshall stickers now available
    FOR SALE
    Sparco Torino 2 sport seats, None resonated Milltek exhaust,
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts, relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
    AVLO's Avatar
    Mar 2012
    Doncaster
    276
    No mate tried to empty it numerous times but not much comes out :/
    AVLO's Avatar
    Mar 2012
    Doncaster
    276
    Quote Originally Posted by Andrew@A.L.D View Post
    Its not a custom
    Ahh thought it was a custom can Andrew. It's mounted on the side of the battery box at the front of the bay.
    mark_S3's Avatar
    Yorkshire & Humber Events Rep
    Sep 2012
    Wakefield
    600
    Your Bad luck continuing Matt?
    You must of upset it, when you keep looking at RS4's.... Lol
    AVLO likes this.
    ***2000 Audi S3 8L APY***
    * Milltek CATback * Milltek 200 Supercell Sports CAT * SuperChips SPS Stage 1 Remap * Forge 008p *
    * 18" Audi TT 240 Sports Alloys in Gunmetal Grey * Pagid Discs with BD Predator Pads *
    * Badger5 v2.2 TIP, JR Filter with Heatshield * N249 Delete * N112 Bypass *
    * PowerFlex ARB Bushes * TFSI Coilpacks * Saikuo Michi S3-OCC *
    * PowerFlex Rear Engine Mount Bushes *
    [IMG][/IMG]
    AVLO's Avatar
    Mar 2012
    Doncaster
    276
    No matey it's not that it's been doing it for about a month now, last weekend I took off the coolant temperature sensor housing which turned out to be where the leaking coolant was coming from and at the same time I cleaned all my TIP and heat shield and since then I have been driving steady so no oil has blown out but last night I decided to give it a bit and once I pulled up I had a look under the bonnet ant the TIP was covered in oil spray
  1. 50mph blow-out... while towing!
    By BahnStormer77 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th July 2012, 15:51
  2. AIR -CON BLOWING OUT HOT AIR ALL THE TIME!!!!....
    By jondonna8276 in forum Air Conditioning
    Last Post: 31st August 2010, 21:50
  3. A lot of air blowing out of the oil filler on 1.8T. Is this normal?
    By Blue_Thunder in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 14th March 2010, 09:04
  4. Manchester blows out congestion charge
    By motorbikez in forum General Chat
    Last Post: 18th December 2008, 19:13
  5. Replies: 11
    Last Post: 15th August 2005, 20:01
